Rev limit problem b16
Old Mar 11, 2010 | 12:15 PM
Hatcheys314's Avatar
Icon3 Rev limit problem b16
I have a 95 civic with a b16a swap and recently it will only let me rev up till 3 grand and then it seems as if my rev limiter cuts on almost as if I have a 2 step on at all times please I need help trying figure out what the problem could be
Old Mar 11, 2010 | 12:17 PM
johnzy00's Avatar
Default Re: Rev limit problem b16
Could your program on your chip be wrong?
Old Mar 11, 2010 | 01:05 PM
machetes77's Avatar
u need a new dizzy but to be sure barrow one from a friend
Old Mar 11, 2010 | 05:45 PM
it isnt chipped and i got my friend to bring over his p28 and the rev limit went up from 3000 to 4500 rpm i have no ideal what the problem could be
Old Mar 16, 2010 | 05:14 AM
Ive been starting up my car everyday just to get the fluids running and it seems as if the car runs fine then i took it around the block and the rev was fine, and then all of a sudden it starts acting up again the car feels like it is dragging it has nowhere near the same power or responce....... any ideas
Old Mar 17, 2010 | 10:26 PM
BuildTheDream's Avatar
I would say dizzy, more specifically I think the ignition coil in the distributor
Old Mar 18, 2010 | 06:37 AM
hondapaulsen's Avatar
TRIAL USER
I have a 92 civic with a d15b... It wont rev past 2500 rpm. I have tried two different dizzy, both of which are practically new. its throwing codes 6, 8, 10, 14,16, 22. Did the same thing with my d16z6. I dont really think there is a problem with all of the things that it is throwing codes for. please help!
Old Mar 18, 2010 | 06:55 AM
vtechjunkie's Avatar
It could be the dizzy, like "BuilkdTheDream" said, it also sounds like the dreaded "limp" mode though. Are you throwing any codes on your stock ECU? If so fix those and get back to us. Let us know if/when you figure it out. Good luck!
Old Mar 18, 2010 | 08:34 AM
so do i just get a new distributor??? its throwing these codes:
17 vss speed sensor
36 Traction control found on jdm ecu's
22 vtec pressure valve
10 IAT intake air tempurature sensor
14 IAc (Eacv) idle air control valve
21 Vtec Spool Solenoid valve
3 Map manifold absolute pressure sensor
brad22486
13
Feb 6, 2021 08:08 AM
Eh2Samuelian
Oct 24, 2015 04:43 PM
tipsey710
Jul 2, 2012 08:01 PM
Boostfed
Nov 1, 2003 05:39 AM
