B20 Vtec Clutch Woes
Old Mar 11, 2010 | 11:51 AM
dansXR2's Avatar
Default B20 Vtec Clutch Woes
So i swapped up a '92 hatch with a b20vtec swap. The PO had the clutch replaced less than 50 miles ago and he said the day after it was replaced it continued to slip. I called the shop and asked exactly what they replaced and they stated they installed a new clutch disc, Pressure Plate, and TO Bearing. I'm kinda lost as this is the last thing I need to get repaired before i start driving it. I've bled it and that helped and adjusted it and that helped a little, but the when you start to depress the clutch pedal, the clutch is fully released at ~1 1/2" - 2" down. What gives? I see no damp spots so maybe the Slave or Master Cylinders are on there way out? Any input in a diagnosis is appreciated.
s13hero
14
Nov 21, 2010 04:57 PM
langjairicer
May 1, 2010 12:08 AM
1993gsrcivic
Transmission & Drivetrain
10
Jan 12, 2009 01:31 AM
MI4$DC5
Apr 15, 2007 09:33 PM
RidinStock
Jun 7, 2005 06:28 PM
