94 EG o2 sensor help!
hey this is my first HT post. i gotta obd1 jdm b18C in my 94 Dx chassis. i currently have no o2 sensor hooked up because... the header i got with my swap is a shorty JG edelbrock. it has no bung for an o2 sensor and it is ceramic so im assuming i cant have a bung welded to it. my test pipe does however have a bung. i was curious if i could use that bung? i dont know where the stock sensor went on this motor so i dont know if the wires will reach the plug?
ALSO
question number two. im throwing code 23 for the KS however it is ran from the KS directly to D3 pinout so thats bothering me. Can i have my GSR ecu chipped or something not to look for a KS? i dont wanna go with a p28 because i like the secondary butterflys
thanks guys
ALSO
thanks guys
first. ditch the stock gsr manifold, its junk.
you an chip your P72 just like a P28.
yes get it chipped for the mean time and disable knock sensor and you can also disable the o2 sensor if you wanted to.
but just put the o2 sensor wherever you can. its better then nothing
and the ceramic is a coating..chip it off and weld whatever you want to
yea ive been looking into gettin the skunk 2 intake mani. i heard that you lose low end torque tho and the motors already lackin enough torque lol. also ive read that the o2 code and the Knock sensor code wont disable vtec but those are the only two codes im getting and i dont think its crossing over. could those be a possible reason? thanks a mill
yeah.
you wont lost power. i had a gsr and got the type r style. some jdm gsr's came with them you can find them for like $50-150 on ebay...those are what skunk2 copied..yes....they copied them..
and they are way better from down low to up high.
plus. once you ditch the intake mani you wont need the heavy bracket for it either thats under it.
chip the ecu
plug in the o2 sensor
get a new manifold
hit vtec down some school zone areas
chip the ecu
get a new manifold
just depends who you run into.
i beleive this is a tech forum.
some think its a "im better and smarter then you, use the search button for evertying" forum
