o2 sensor. can it be fixed?
I got this Buzzing crapy test pipe from Y2Kmotors. and they put the bung on the wrong side of the pipe. so the o2 was pointed stright down, rather then up. I chose to use the car to get home annd come back the next day to cut and weld the back flange upsidedown so i could flip the whole pipe. but i did not make it back before breaking it.
If i surgically removed the shinny metal cap and spliced the wires back togather would it work? also i have a p28 with JDM D15B, will not using the 2nd o2 sensor effect my car at all?
Re: o2 sensor. can it be fixed? (THC1107)
Nope, not at all. the p28 only looks for 1 o2 sensor, as long as your sure that isn't the one the ecu is looking for just plug up the hole and you should be good
Re: o2 sensor. can it be fixed? (VTcivicHB)
If thats your 2nd o2 sensor then just cap the bung and your set.
But to fix that o2 sensor i think youll need to run new wire out of that cap.
