triying to rase my comperetion
Old Mar 11, 2010 | 08:42 AM
josh909's Avatar
Default triying to rase my comperetion
i herd that you can put DOHC zc pistons in a d16y7 block? is that true?im runing a z6 head on the block will the valvs cleer and not hit? thanks
Old Mar 11, 2010 | 09:27 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: triying to rase my comperetion
they fit. they are pretty much the same. minus compression heigth
Old Mar 11, 2010 | 11:34 AM
josh909's Avatar
ok they fit do i loos compretion or gane compretion? i am trying to find haw to make my car better.
Old Mar 11, 2010 | 04:42 PM
I'm not Rick!
use a compression calculator on google.
Old Mar 11, 2010 | 05:19 PM
D16SiHatch's Avatar
compression will be in the 12's.. so good luck with that lol
Old Mar 11, 2010 | 06:50 PM
iamthefollower's Avatar
Yeah I had a buddy who had done this and was in the high 12's on compression.
Old Mar 11, 2010 | 07:41 PM
Schister66's Avatar
Man U FTW
Holy Hooked-on-Phonics phoenetic spelling Batman!
Old Mar 11, 2010 | 09:22 PM
ricky21's Avatar
They'll fit. And you could also use a thinner head gasket from what ive heard. (But do not quote me on that)
Old Mar 12, 2010 | 05:12 AM
Matt93eg's Avatar
LMAO!! I can't believe there were 5 replies before someone brought this up.
Old Mar 12, 2010 | 07:53 AM
newtron63h's Avatar
i was doing an olympic quality facepalm on the topic name
Old Mar 12, 2010 | 07:58 AM
builthatch's Avatar
MiG-21 superfan
if you are talking about p29/pm7 pistons and not flat pg6b pistons from 86-87 d16a1...
yes, they will physically work, but you will need swap to obd1 and run the proper tuneable ecu to run such a combination.
with the y7 head you will be in the mid-12's static compression.
put this in your favorites - http://www.knology.net/~jediklc/D.htm
jawsiiv
Jun 10, 2009 04:49 AM
CR3X
Jun 25, 2008 11:26 AM
89civichatchback
Jun 2, 2003 11:48 AM
crxtreme27
May 1, 2003 11:19 AM
