H22a in a 92 cx
Old Sep 8, 2002 | 11:14 AM
M1kevtec's Avatar
New User
Default H22a in a 92 cx
I am planning on dropping a H22a into my 92 cx--I've contacted HASPORT for a custom wiring---they quoted my $299 plus shipping and also requires me to ship both of my wiring cores--from the cx and the prelude. I thought this was pricey unless this is what it goes for. Has anyone have ordered a wiring harness from them and how was the quality of product?
I have HCP mounts
92 accord intermediate shaft
93 integ axles
92 prelude si shifter assembly
and in need of wiring harness or convert what i have but lacking of knowledge in this area.
I'm going to be doing my own swap with the help of friends but I want the downtime of my car as short as possible.
Please assist me if you know about this swap or if you have any suggestions.
Thanks
Old Sep 8, 2002 | 05:27 PM
Timmayeg's Avatar
New User
Default Re: H22a in a 92 cx (M1kevtec)
get a civic EX wiring harness it plugs right in your car and all you have to do is make some of the sensor wire longer ie- altenator, and a few others- thats what i did- dont waste your time on the place wiring kit when you can do it yourself
also i dont think the 92 accord 1/2 shaft will work i think you need a 90-91 but i could be wrong
Old Sep 8, 2002 | 06:14 PM
H22aEk9's Avatar
Hey wassup don't waste your money paying someone else to do your wiring harness, its acutually pretty easy but i would suggest get a helms manuls for both motors but mainly your going to be lengthinging wires like the atelrnator, oil sedning unit , fuel injectors plugs also need to be converted to the h22 motor and addings extra wires for your resistor pack, u'll be adding 3 vtec wires, a knock sensor i didnt do egr in my swap becuase i had a jdm ecu but thats more wires too there a few more once u start ull see, but i mean its not that hard ahah good luck o yea by the way i have a 95 motor in my 98 hatchback
Old Sep 8, 2002 | 06:18 PM
H22aEk9's Avatar
also your axle setup is right there is two axles setups
Accord intermediate with 90-93 teg axles
or Prelude intermediate and 94 up teg passenger side axle and 87-89 teg driver side this setup is stronger but harder to find im using this one
also i suggest u use a 94 del sol vtec radiator jux call up some aftermarket radiator company in your area and rember to ask for double row its thicker for more cooling u'll need it
Old Sep 9, 2002 | 02:02 PM
M1kevtec's Avatar
New User
thanks everyone, I will be performing the swap myself and save me about 2000 worth of labor
Old Sep 9, 2002 | 02:06 PM
keebler65's Avatar
doing it yourself gives you bragging rights
Old Sep 9, 2002 | 08:37 PM
M1kevtec's Avatar
New User
Default Re: H22a in a 92 cx (goldhatch)
I would appreciate that.
here it is
1992 civic cx
1995 JDM H22a w/LSD
JDM Obd1 stock P13
92 Prelude Shifter Assy
92 Accord Intermediate Shaft
93 Integ Axles
HCP mount kits
Radiator -- TBD
anything else?
Send any info, suggestions, opinions, questions you got.
vwible
Aug 10, 2005 03:38 PM
dsmarefaster
Nov 8, 2004 08:28 PM
B18CUL8R
Jun 6, 2004 01:10 PM
Touch
Mar 12, 2003 10:51 AM
JdmCIVIC853
Feb 23, 2003 08:30 AM
