d16y8 ecu wireharness questions
Old Mar 10, 2010 | 07:00 PM
madsci's Avatar
Default d16y8 ecu wireharness questions
i got a 96 d16y8 and i got a p28 ecu and i was woundering if this is the right ecu and wireharness for my motor and for some reason my vtech isnt working
Old Mar 10, 2010 | 07:16 PM
goldfinger93030's Avatar
Default Re: d16y8 ecu wireharness questions
if its going into an obd2a civic then yes
Old Mar 10, 2010 | 07:18 PM
hondaboynky's Avatar
d16y8 harness is obd2 and the p28 is obd1 so you will need a jumper harness
Old Mar 10, 2010 | 07:22 PM
o yeah thanx for the correction i forgot about that
Old Mar 10, 2010 | 07:25 PM
itsnotfast's Avatar
Yes and no. The P28 should make it run fine; however the proper ECU for your car would be a P2P. Your car is OBD2a and the P28 is an OBD1 ECU. Thw wiring harness should be the one that the car came with, I highly doubt someone would have changed it.
Old Mar 10, 2010 | 08:03 PM
madsci's Avatar
the motor is in a 94 hatch.. so is that one reason my vtech isnt working as well
Old Mar 10, 2010 | 08:13 PM
itsnotfast's Avatar
If done right, it should work.
Old Mar 10, 2010 | 08:22 PM
madsci's Avatar
so with my p28 ecu and the wireharness my vtech should work and is everything i have the right set up?
Old Mar 10, 2010 | 08:25 PM
itsnotfast's Avatar
It should work if everything is done correctly to accomidate the P28. Is or was your car or the donor car automatic? Do you have any CELs?
Old Mar 10, 2010 | 08:28 PM
madsci's Avatar
i bought this car off of my buddy and it was never an auto his dad owned the car from new and gave it to him and i bought it off of him so what exactly do i have to do to make everything work properly because im building the motor for racing and nitrous
Old Mar 10, 2010 | 08:37 PM
itsnotfast's Avatar
Keep the P28 then and build it. First you need to diagnose the VTEC issue. At what point did it stop working. Has it ever worked in that car with that motor? Is the car even wired for VTEC? What motor came out of it?
Old Mar 10, 2010 | 08:45 PM
madsci's Avatar
umm well ive driving alot of vtech motors and my buddy has the same motor and exhaust system and u can hear the vtech kick on and i cant with mine and i got a wire runnin down fom the vtech silinod to the ecu and that motor came with the car but i had to replace the bottom end with the y7 bottom end because at the time i could afford the rebuild the bottom end
Prentice916
Jul 31, 2017 10:02 AM
ej6kid
21
Sep 24, 2010 08:26 PM
Site123
Engine Management and Tuning
Mar 13, 2009 11:44 AM
Eibach95Civic
22
Apr 15, 2007 09:05 PM
honda_turbo
Apr 2, 2006 09:43 AM
