weird idle
Old Mar 10, 2010 | 06:56 PM
1993gsrcivic's Avatar
Default weird idle
i got a eg wit a jdm b16 just put a type r intake mani on today everythings good but it was idleing wierd it was surging from 800 to 2000rpms so i read some stuff checked for vac leaks and everything went over it all everything was good but then
i capped off the pcv thing on the front side of the mani and the car idled perfect so i figured that line had a hole in it
i got a new line and ran it from the black box on the back on the block to the mani like it should be i just took out pcv valve and then car was doin the same **** i kno the pcv system relieves crank pressure and not hooked up can wash out ur rings
if i take the hose that supposed to go to the mani and leave it open or hook it to a catch can will it hurt anything? will that be safe?
Old Mar 11, 2010 | 12:16 PM
civic sand rail's Avatar
Default Re: weird idle
I just had the same problem............ Im building a sand rail with the engine though.
This may sound weird but trust me and try it!!!!!!1
Here is what totally fixed if for me.
Bleed the air out of the coolant lines. There is a bolt with a nipple on the coolant housing at the front of the engine. start the engine and let it warm up . wear thick gloves and crack it open and bleed all of the air out.
Do this a couple time while keeping an eye on your rad coolant level.
WORKED 4 ME
Let me know if it worked for yourself.
Steve.
Old Mar 11, 2010 | 04:06 PM
i blead it i ran the car unpluged to fan let it get to temp and the opened the radiator it had alot of air in it and it was still the same
Old Mar 11, 2010 | 09:53 PM
Keep topping up rad and running the engine. Maybe there is still air in the system
Old Mar 12, 2010 | 04:46 PM
KWayRacing's Avatar
It is possible that you now have the throttle cable a little too tight opening the throttle plate slightly. This intail makes the IACV try to compensate for it and then flips out, I think the cable deflection spec is 13mm. Either way there should be a little slack between the cable bracket and the throttle shaft. Just a thought.
Old Mar 16, 2010 | 07:42 AM
i got it it was me not havin a pcv valve thanks for ur help anyways
kickadog55
14
Oct 10, 2012 07:25 PM
tmrtwo
Apr 10, 2009 09:21 AM
lurkin' eg
Jul 18, 2008 10:15 PM
lude98SH
Dec 9, 2007 03:05 PM
VTC_CiViC
Dec 21, 2004 06:29 AM
