Using Plastigauge
Old Mar 10, 2010 | 02:19 PM
rich7777's Avatar
Icon2 Using Plastigauge
Hey guys, i have a question about using grease with plastigauge.
In the instructions it says to use a smear of grease on the crankshaft journal, so i did and the clearences are where i wanted them.
But i then tryed it with no grease, as someone told me i'm suppose to do it dry as it will effect the reading and the clearences where quite loose.
Which do i go for ? I have used mainly black bearings so even if i had to do it dry the only next size up would be blue and that still would'nt be enouth. Also i went buy the letters on the engine and numbers on the crank.
The clearences were .0015 with grease & .002 without ? ?
Cheers
Old Mar 10, 2010 | 05:59 PM
vanilla_rice's Avatar
Default Re: Using Plastigauge
Follow the instructions and use the grease. Without lube the gage won't be free to spread out as much, thus you'll get a thinner line and a erroneous wider clearance. The gages will only read correctly if you follow the instructions.
Old Mar 11, 2010 | 11:46 AM
johnzy00's Avatar
well put!
Old Mar 23, 2010 | 06:48 PM
tinkerbell's Avatar
i just did mine 'dry' and they came up at 0.002 across the crank...
that's why i came on HT to search, and found your thread
my plastigauge packet didn't come with instructions,
so do you guys mean that i need to put the assembly lube on the journals before i put the plastigauge on them?
this is the first i have heard that?
Old Mar 23, 2010 | 07:24 PM
miguel329's Avatar
ive seen a few videos youtube.
Old Mar 23, 2010 | 07:29 PM
tinkerbell's Avatar
i am more interested in seeing the instructions the guys above are referring to?
these are the only instructions i could find:
http://www.3sx.com/store/faq/plastig...ctions-800.jpg
ls_vtec_da
K Series
Nov 19, 2010 10:28 PM
boostedefhatch
May 13, 2010 11:02 AM
TylerB
Mar 14, 2009 03:50 PM
unknown0001
May 29, 2005 08:54 AM
ImprtTunr
Jan 20, 2002 11:46 PM
