what are good rods and pistons for a b16a, going all motor
Old Sep 8, 2002 | 10:09 AM
b16powwer's Avatar
Default what are good rods and pistons for a b16a, going all motor
i have a 91 crx si w/b16a1 (cable) i wanna go all motor, i am planing on doing the bottom end this winter, i would like to know what kind of rods and pistons w/rings would you go whet, for a all motor b16a.
Old Sep 8, 2002 | 10:58 AM
Jared's Avatar
Default Re: what are good rods and pistons for a b16a, going all motor (b16powwer)
eagle rods work great, ctr pistons yield good compression, but for something a little stronger, get a set of JE or arias.
Old Sep 8, 2002 | 09:44 PM
89ctrcrx's Avatar
Default Re: what are good rods and pistons for a b16a, going all motor (Jared)
Ctr pistons are great for going all motor and the stock b16 rods are fine too. No need to waste the money on those.
Old Sep 9, 2002 | 06:51 AM
dohcsideSi's Avatar
Default Re: what are good rods and pistons for a b16a, going all motor (89ctrcrx)
i have a set of ctr's on b16 rods - 25 over for sale
Old Sep 9, 2002 | 06:53 AM
b16powwer's Avatar
Default Re: what are good rods and pistons for a b16a, going all motor (dohcsideSi)
dohcsidesi, where you live. and how much you asking. do rims come along, and what is the different between .25 over and standerd. email me at faraj77@aol.com thanks
Old Sep 9, 2002 | 05:05 PM
Sunrise City Rider's Avatar
.25 refers to the oversize bore 81.25mm...these are the replacement for factory pistons when you have passed the acceptable piston to cylinder wall clearance...These are Factory Honda Issue and will allow you to hone or bore out the stock cylinder sleeve to this size rather than having to resleeve the block...The rings you will need for these pistons are oversized 81.25mm...
If you want a fresh surface for the piston rings to seat to, you will want oversize pistons...The CTR Pistons are excellent in a B16a block using stock size connecting rods...If you use Forged pistons and want an alternative to Crower and Eagle Rods, look at REV Valves Connecting Rods...They offer a Rod that is better than Eagle for about $200 less than Crower Billet Steel...Call (954) 772-6060, ask for Ralph and he'll take care of you...Mention that I reffered you and he will give you discounts...They also have awesome valves that use a flat face for greater strength and increased compression...
Good luck and build it right...Take your time and blueprint the block...
Zee
intikab@cs.com
Old Sep 12, 2002 | 09:11 AM
dohcsideSi's Avatar
i'm in ny about $415 shipped (already on the machined b16 rods) w/ brand new rings in the box...
Old Sep 12, 2002 | 09:56 AM
civicgsr91's Avatar
i have a set of brand new ctr pistons with rings for $200.
turbocivic91@yahoo.com
GT500FTW
Sep 6, 2015 01:32 PM
vyrus
Nov 14, 2012 09:49 AM
Scotland:EF3
Feb 24, 2007 09:04 PM
pheonixb16aguy@hondaswap
May 25, 2005 04:27 PM
djickabod
Oct 26, 2003 12:07 PM
