Engine Swap, B16 -> B18
Old Mar 10, 2010 | 09:27 AM
jakl's Avatar
Default Engine Swap, B16 -> B18
Hello, I currently drive a 95 del sol vtec with a b16a(pr3, not b16a2) in it and im looking to get more power. I want to do an engine swap to the b18c1 and was wondering what i needed extra. I was planning on buying a long block from hmotors which comes with the following:
- Motor
- Intake Manifold
- Exhaust Manifold
- Injectors
- Fuel Rail
- Throttle body
- Alternator
- Distributor
Is there anything that im missing aside from the ecu to get it running? I heard that I can use the b16 wiring harness and just add a few sensors or something. Any help will be greatly appreciated
Old Mar 11, 2010 | 10:13 AM
jakl's Avatar
Default Re: Engine Swap, B16 -> B18
any help please
Old Mar 11, 2010 | 10:22 AM
johnzy00's Avatar
You should be set! Obviously you will need the right ecu. Axles are the same. Are you staying with the same OBD? If so that should be fine as well. If not will need a jumper. Off the top of my head the only thing that the c1 has that the b16 doesn't(depending on what year) is the IAB's.
Brettw
Apr 29, 2013 04:47 PM
HopperIsMyCar
Nov 20, 2011 04:42 PM
kevheslop
Aug 27, 2009 04:21 AM
Fired Honda
Jul 26, 2003 08:17 PM
