Suspension & Brakes Theory, alignment, spring rates....
NSX Brake calipers on my 4x100 gs-r
Old Mar 10, 2010 | 07:15 AM
RedintegraGS-R's Avatar
Default NSX Brake calipers on my 4x100 gs-r
Hey I just bought a gs-r a few months ago and have been buying parts like crazy haha. My question is what all do I need for my gs-r to have nsx brake calipers? Its 4x100 and I do plan to keep it that way due to the new rota slipstreams I bought lastweek so anyways what parts and fabrication would I need??
Old Mar 10, 2010 | 07:28 AM
roastbeefrichie's Avatar
Default Re: NSX Brake calipers on my 4x100 gs-r
PARTS LIST
NSX front calipers w/ brackets & pads
ROTORS
a. 11" fastbrakes.com 4X100 rotor
b. re-drill prelude VTEC rotors to 4x100
once you acquire the NSX calipers, remove the brackets & have them machined
Originally Posted by roastbeefrichie
approx 3.2 mm (or an 1/8")
examine the bracket (where the 23T is stamped) & look for the #3 to be cut in half
the amount machined should be equivalent on both sides on each bracket (which mates to the knuckle)
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-brake-upgrade-integra-front-brakes-dx-knuckles-1484555/
once your brackets are milled, everything is a bolt-on
bleed your brakes, & break in your pads.
the NSX calipers/11" rotor will clear 15" oem honda/acura wheels, you shouldn't have clearance issues with your rota slipstreams
Old Mar 10, 2010 | 09:09 AM
Ok sick thanks a lot bro
Old Mar 10, 2010 | 11:17 AM
no prob...this applies to ITR calipers (stamped 17CL15VN) & legend GS 2-pots as well
Old Mar 12, 2010 | 03:41 PM
dc4teg95's Avatar
PARTS LIST
ROTORS
how much needs to be milled off the bracket
Old Mar 12, 2010 | 10:10 PM
you'll need to machine
* approx 3.2 mm (or an 1/8") *
examine the bracket
on 23T bracket, look for the #3 to be cut in half (3.2mm)
on 25T bracket, look for the #5 to be cut in half (3mm)
on 28T bracket, look for the #8 to be cut in half (2.5mm)
the amount machined should be equivalent & parallel on both sides on each bracket
the milled brackets w/ NSX calipers on 11" rotors will clear 15" oem honda/acura wheels
Old Mar 12, 2010 | 10:23 PM
approx 3.2mm (or an 1/8")
here's a few more pics so you can get a better idea:
Quote:
Originally Posted by Wagon Guru @ hondacivicwagon.com, pic taken from http://www.hondacivicwagon.com/bb/vi...php?f=8&t=6241
Quote:
Originally Posted by lukeailburn,
Quote:
Originally Posted by kommon_sense,
Old Mar 14, 2010 | 08:28 PM
JsRacingEM1's Avatar
Does the same go for a 00 civic si? The only similar setup I can find is on the Wicked Automotive/Prima Racing 99 civic si (NASA Honda Challenge H1 car). They said that they used the NSX calipers with 282mm rotors. Is there only one source for "pre-made" larger 4x100 rotors? Otherwise re-drilled honda rotors? Prelude rotors the only ones that will work with this setup? Also what aftermarket SS braided brake lines can be used? Thanks for any help/advice posted!
Old Mar 14, 2010 | 08:52 PM
yes, this applies to 99-00 civic Si
90-01 integra
90-00 civic EX
del sol B16
www.fastbrakes.com has the 11" rotor in 4X100
the 11" prelude VTEC front rotor re-drilled 4x100 is prob most popular due to the availibilty/acess of off-the-shelf parts
use of NSX brackets (stamped 28T) w/ NSX calipers
Originally Posted by migs, "NSX Caliper Install + Legend GS 28mm rotors"
https://honda-tech.com/forums/acura-integra-type-r-8/finally-nsx-brake-caliper-install-legend-gs-rotors-239844/
HondaMarketplace, For Sale by BE2
use of NSX brackets (stamped 28T) w/ NSX calipers on NSX rotors re-drilled to 4X100
http://hondamarketplace.com/showthread.php?t=2736174
any 88-00 civic or 90-01 integra OEM front brake hose will work with this upgrade, so if you're after SS lines, get a set for your application, which is: 99-00 civic Si
Last edited by roastbeefrichie; Mar 14, 2010 at 10:49 PM. Reason: NSX Brake Calipers on my 4X100 integra GSR
Old Mar 14, 2010 | 09:01 PM
Thanks for the GOOD info/reply (roastbeefrichie)!!! Appreciate it!!!
Old Mar 14, 2010 | 09:02 PM
TurboTeg332
Jul 28, 2019 06:40 PM
jdm_dc_fan
Suspension & Brakes
Aug 17, 2007 10:21 PM
DA9Rood
Aug 26, 2006 02:35 AM
PogKai
Suspension & Brakes
Nov 7, 2005 06:45 PM
m R g S r
Aug 11, 2005 10:43 PM
