Brake light switch?
Old Mar 9, 2010 | 10:42 PM
jasoncanseeoh's Avatar
Default Brake light switch?
Okay, so I accidentally cut my brake light switch from my original harness. And I'm trying to rewire it up.
Here's my question:
(Brake switch is in center of picture.)
Is it okay to just run the white/green wire mentioned in the picture, THEN just have a ground to ANYTHING/ANYWHERE?
Or do I have to hook it up to the brake light FIRST, then ground from there?
To sum it up, white/green wire for sure...... then where do I have to hook up the ground? Is it okay anywhere or what?
Thanks for any help in advance!
Old Mar 10, 2010 | 08:31 PM
Default Re: Brake light switch?
bumpin.
Old Mar 11, 2010 | 08:27 AM
g morning bump
Old Mar 11, 2010 | 09:32 AM
kyden's Avatar
the brake light switch completes the circuit. one wire is the 12v feed, the other is the power to the brake lights. it grounds through the bulbs.
Old Mar 11, 2010 | 10:08 AM
I followed the white/green wire from the fuse box this morning..... it was a wire needed for the cluster harness. Not the brake light switch.... am I doing something wrong?
Old Mar 11, 2010 | 10:35 AM
kyden's Avatar
from the one under the dash or the hood?
Old Mar 11, 2010 | 10:38 AM
Under the hood.
Old Mar 11, 2010 | 04:40 PM
Old Mar 11, 2010 | 08:11 PM
fcm's Avatar
fcm
Old Fart
As you can see there is more then one white/green lead lead in the car, at least two of them run from engine bay to inside the car.
Without knowing exactly what you mean by, "I accidentally cut my brake light switch from my original harness" but I would guess the white/green lead you need should be coming out of the dash harness pretty close to where the switch is, did you also cut the green/white lead from the switch?
As mentioned, the BLS closes a 12V+ circuit, there is no ground , white/green in, [from 20A fuse] and green/white out, [to brake lights]. 94
Old Mar 11, 2010 | 08:30 PM
Yeah, dude. I cut the whole plug. I have no clue why I can't find where I cut it. I'm searching all over. As I stated before, I started following the wire and it led me to a different plug that goes into the heater I believe?
I'm gonna look tomorrow for those wires and hopefully update you guys.
I know there isn't much back there, but knowing exactly where the plug is will help greatly. Is it on the dash harness? Or is it on the main harness that's connected for the firewall?
mahgnibb
12
Oct 23, 2017 12:29 PM
putzkrieg
Dec 3, 2010 07:19 AM
jasoncanseeoh
Mar 11, 2010 08:27 AM
Padronis
Jun 29, 2005 08:13 AM
