need help with vtec
Old Mar 9, 2010 | 12:29 PM
hondaboynky's Avatar
Default need help with vtec
currently mini meing my 99 civic dx with a z6 head i have the diagram for the dizzy just need to know how to wire vtec to the ecu? i will be running a p2p ecu any information will help!!!
Old Mar 9, 2010 | 12:33 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: need help with vtec
Old Mar 9, 2010 | 12:52 PM
so i would use b-12 and c-10 correct and if so what color wires to where? sorry ive never pinned in vtec? also where would i find the pieces to pin it in sorry for the ignorence the more information the better. the picture is very helpful though
Old Mar 9, 2010 | 01:58 PM
ttt
Old Mar 9, 2010 | 03:11 PM
ifIexplode's Avatar
The color of the wire doesnt matter if youre gonna hardwire VTEC in. Hit up the junk yard and cut off the ECU connector from any civic, I think the dash pins for the gauge cluster will work too. Ive used pins from a radio harness before. Make sure you cut and solder. No butt connectors please.
Old Mar 9, 2010 | 04:50 PM
thanks for the help also do i need to hook up the knock sensor?
Old Mar 9, 2010 | 07:41 PM
ifIexplode's Avatar
Yes you will need to wire up the knock sensor, The P2P ECU will look for it and will throw a code if it isnt wired up, Also youll be in limp mode.
Some people say you need a shielded wire for the knock sensor incase of false signals, But to be honest i never have, Ive always just used a regular wire and havent had any problems.
Also your y7 motor should have the threads on the back of the block for the knock sensor, Id try and find a used ones, They arent cheap new.
fryman
Sep 24, 2008 10:07 AM
turbodelsolb16a2
Jun 15, 2008 06:23 PM
94eg'n
Sep 24, 2007 04:09 PM
mustang5.slow
18
Feb 28, 2007 07:33 PM
vtecn8ive
Apr 20, 2006 09:14 PM
