where is the fuel pump?
Old Mar 8, 2010 | 09:57 PM
wickedplastikman's Avatar
Default where is the fuel pump?
how do you get to the fuel pump in a 93 del sol? is it underneath the panels behind the seats?
Old Mar 9, 2010 | 02:59 AM
ChrisRogers's Avatar
Default Re: where is the fuel pump?
The fuel pump is in the fuel tank and is reached through an access panel inside the car in the rear passenger or cargo area.
Old Mar 9, 2010 | 11:15 AM
i know its in the tank but which panel do is it under?
Old Mar 9, 2010 | 01:09 PM
delsolproblems's Avatar
The fuel pump is underneath the "personal trunk" panel behind the seats. The panel with the two plastic lockable boxes- that needs to be removed and the pump is right under it. I believe mister Rogers was referring to a civic fuel pump.
Old Mar 9, 2010 | 01:17 PM
perfect. thank you.
Old Mar 9, 2010 | 01:44 PM
when i buy a new walbro, do i need the whole kit? or just the pump for the del sol? think the kit just comes with a new plug...
Old Mar 9, 2010 | 02:01 PM
You can just buy the pump and then purchase a new strainer at a local parts store. There's a short length of hose attached to the pump that can be replaced for a dollar or two and fresh hose clamps should be installed with it. It sometimes comes with the pump. Aside from some grease for the electrical connector, that's everything you'd want to replace with the pump. You might borrow a fuel pressure tester while you're at the store to check everything when you are done. A new fuel filter is also a good idea with the new pump.
Old Mar 9, 2010 | 04:24 PM
cool thanks again
lostforawhile
Welding / Fabrication
19
Mar 12, 2011 10:18 AM
prelude994e
Sep 13, 2004 11:23 AM
GSR_Hacker
Jul 8, 2002 06:50 PM
