just installed turbo in ek, now will barely run
alright so i just put in my turbo kit finally. i have a walbro 255, dsm 450's, p06 ecu with turbo basemap. the car ran fine with the n/a basemap that i had. now with both map and tps connected it won't run. however, the car will run with only the tps connected. if i put the map plug on the tps, the car will rev to 2500 and then won't rev until it idles again. will not run with just map.
also, the car is running super rich. like 4 gallons in 50 miles. it's bad.
any suggestions on what to do? should i try the n/a basemap again?
Is your check engine light on ?
What map sensor is the ecu mapped for ?
Do you have any check valves/missing link installed ?
Are you running a resistor box ?
Did you contact who ever you bought the basemap from for advice ?
brutekiller787
Mar 12, 2010 06:12 PM
brutekiller787
15
Mar 9, 2010 05:40 PM
