F20B Harness & ECU
Old Mar 8, 2010 | 04:58 PM
Seamless Design's Avatar
TRIAL USER
Default F20B Harness & ECU
Hi all,
First of all I have done quite a bit of searching here...lots of good information.
I recently bought a F20B engine (with all sensors) and transmission. The seller did not have any wiring. This will be going into a 'kit-car' type vehicle - so I have no existing wiring or ecu. This is where I differ from most of the accord/civic/prelude installs. All I want is OEM turn key reliability - no need for more power in a 1200-1400 lb car.
I am trying to determine the best and cleanest wiring options. So far these are my options:
1. Buy proper F20B harness and ECU (quoted $400 from engine importer).
If I go this route, can I use a Prelude gauge cluster? Any other issues with immobilizer?
2. Use a Prelude harness and make necessary changes to injectors, dist, ect...
3. Convert to OBD1 and use a P28 ecu with modified harness from???(anything obd1)
Any info would be great.
Thanks
Old Mar 11, 2010 | 06:42 PM
TRIAL USER
Default Re: F20B Harness & ECU
Well, after doing some more research i've decided to go with a obd1 vtec harness and use my p28 ecu. I understand that I will have to do a few modifications but we'll start there.
Cnorton1112
Engine Management and Tuning
Oct 15, 2015 05:52 PM
yellowcanary.
Mar 16, 2015 02:03 PM
jeffruby
Mar 19, 2006 06:30 PM
importpower
Feb 10, 2004 08:34 PM
CWESTINAP1
Nov 7, 2002 11:28 AM
