97 EX, auto, how much trans fluid?
i think its between 6-8 quarts. only way to get it alll flushed is to jack it up and put the car up on jack stands in the front. pull both hoses from the radiator at the bottom. turn the car on and put it in gear and let it pump the tq convertor out. dump out about 3 quarts then put it back in park refill the fluid thru the dip stick with 4 quarts. then repeat this again. honda transmissions do not have a filter to replace on them its all interrnal.
open up the filll plug and add 2 quarts. you probbaly didint loose much. in the back behind the passangers axle thiers a 17mmm nut thats the fill hole. fill it up through the dipstick untill u start to see it start to run out. then put the fill hole bolt back on. and your done
halfkoreanboy
Apr 26, 2023 04:40 PM
kamnamurt
Mar 25, 2014 10:07 AM
