rack and pinion
rack and pinion
whats the difference in the rack and pinions on a 92 civic and 97 civic. i'm wanting to swap a 92 civic manual rack into my 97 civic for a h22a swap. then i'm going to swap the power steering back over to the 92 civic. will the racks bolt up? the part numbers between years are different. meaning the manual racks have diff part numbers and the power racks have diff part number between the two years.
has anybody done this?
I'm not Rick!
Re: rack and pinion
if you want a manual rack get a dx rack, some of those were manual. or you can rebuild yours with manual parts. cap the fluid ends after filling up the rack with fluid.
i have a manual rack in my car and im yanking it out to rebuild it with a power steering rack and pinion (tighter tolerances) or getting the Qualife rack n pinion (road racing)
Re: rack and pinion
what ever will make it easier to steer with no power steering. the car that has the h22a now has the lines capped and it is a mother to steer. weather your moving or sitting still its hard to steer.
Re: rack and pinion
A manual rack is still harder to steer than a power rack, but the manual rack will be easier to steer than a power rack with no pressure to it.
I'm not Rick!
Re: rack and pinion
true. manual rack realy sux. but i dont regret it. i have more control then the car does with it. and it will be even better when i have a quick ratio rack n pinion www.jhpusa.com has them for sale
Re: rack and pinion
Actually you can make an EK 3.2 turn lock to lock with OEM parts.
http://www.jdmuniverse.com/forums/ho...ek-owners.html
Dokta
09-16-2010 12:00 PM
