Are all Stock Honda Map Sensors the same?
Old Mar 8, 2010 | 11:56 AM
mouab18c1's Avatar
Icon2 Are all Stock Honda Map Sensors the same?
Like the title says im wondering if all stock honda map sensors the same? Or to be more accurate obd2 map sensors? Like can I use an integra map sensor for a Honda Accord?
Old Mar 9, 2010 | 06:13 PM
mouab18c1's Avatar
Default Re: Are all Stock Honda Map Sensors the same?
Old Mar 9, 2010 | 06:57 PM
GhostAccord's Avatar
Yes
Old Mar 9, 2010 | 07:40 PM
arkangel2487's Avatar
they all read the same but my not fit the same
Old Mar 9, 2010 | 08:07 PM
j3wman's Avatar
this indeed is a good question
Old Mar 10, 2010 | 06:14 AM
nus_dogg's Avatar
Yes siR. The stock map sensor can go from a D16 to a GSR and F22 to an H22. They're all the same like mentioned above.
Old Mar 10, 2010 | 08:45 AM
SOHCArchangel's Avatar
makes a trip to the junk yeard less of a headache
Old Mar 10, 2010 | 09:00 AM
Casp3r88's Avatar
question where is the map sensor located
Old Mar 10, 2010 | 09:07 AM
Casp3r88's Avatar
and how do you tell when it is goin bad or bad?
Old Mar 10, 2010 | 09:14 AM
i work for firestone and have never replaced one. i doubt ull run into one thats bad otherwise the car just wont start. or run like crap then die. but most of them are right on the throttle body. it will say map or manifold absolute pressure on the sensor
Old Mar 10, 2010 | 02:25 PM
mouab18c1's Avatar
Thanks that is what I thought but just had to clerify it. Thanks again people
Old Mar 10, 2010 | 04:40 PM
j3wman's Avatar
to test it u gotta back probe it and ****, i cant remember but i got my sheet from Honda Electrical class in my car, i just dont wanna go outside
Old Mar 10, 2010 | 05:14 PM
TwistedEX's Avatar
Just had to do this.
With the key in the ON position (not running) unplug the MAP connector and check the voltage between the yellow/white wire closest to the firewall (positive) and the middle green/white wire (ground) of the connector. It should be around 5 volts.
Plug it back in, and backprobe the engine side yellow/white connector (still positive). -Note: I used the (sanded off) intake for ground here, but I may just backprobe the green/white when i check it again.
Turn the key to the ON position again, and use your engine side yellow/white backprobe to check voltage. It should be between 1.5 and 3.5 volts.
Start the car and see if the voltage changes on the engine side yellow white wire with the rpms. Voltage should increase as vacuum decreases. This means at idle there should be low voltage (high vacuum) and at higher rpm's higher voltage (lower vacuum). It should be between 2.5 and 4.5 volts with the car running.
"manifold vacuum is high when the engine is idling and decreases as the throttle is opened allowing manifold vacuum to become equal to atmospheric levels." -Haynes
Old Mar 10, 2010 | 06:17 PM
mouab18c1's Avatar
?? Im confused on what you guys are talking about or just too lazy to read your whole post. I just jumped the ecu and got code 3 for Map Sensor. But I was just wondering if all Honda map sensors were compatable with other stock honda Map sensors
Old Mar 10, 2010 | 06:54 PM
No need to be confused. I didn't know what was going on at first ether. I thought they were going over the top answering your question. It was after all just a yes or no question. But I think they are answering this guy who jacked your thread.
Old Mar 10, 2010 | 06:57 PM
mouab18c1's Avatar
Originally Posted by GhostAccord
I didn't know what was going on at first ether. I thought they were going over the top answering your question. It was after all just a yes or no question. But I think they are answering the guy who jacked your thread.
Haha funny ****! I didn't pay any attention to the dude jacking my thread but oh well..LOL
Old Mar 11, 2010 | 10:44 AM
nus_dogg's Avatar
Haha! Thread jacked.
Old Mar 11, 2010 | 12:43 PM
TwistedEX's Avatar
Oops, sorry. I can delete my overboard how-to if you want?
Old Mar 11, 2010 | 02:26 PM
mouab18c1's Avatar
Don't matter to me, as long as you got what you needed I have no issue.
hatchBK4life
Feb 3, 2010 12:08 PM
rnbguy
Jan 20, 2008 03:46 PM
ALL MOTOR DA
Jun 8, 2006 02:35 PM
4dooritr
Feb 24, 2006 02:59 PM
MugenFlaredCRX
Jan 11, 2005 08:54 PM
