sk2 pro2 cams
Old Mar 8, 2010 | 09:35 AM
ef-hatchcrap's Avatar
Default sk2 pro2 cams
Well my buddy bought some pro2s for his b20vtec. the head has dual valve springs and titanium retainer along with a p+p. So he has the valve train for them.
My question is I installed the cams adjusted the valves to .007in and .008eh. Went by sk2 guidelines and put the exhaust cam advanced 4* and the intake cam 2*. Went to take it for a drive and at 5k right when vtec should engage its just break up and wont rev any higher. Not throwing any codes either.
Has anyone ran these cams in a b20vtec setup before and what did you do to install them? Need to fix it so he can go get it tuned
Old Mar 8, 2010 | 10:57 AM
riceburner700's Avatar
Default Re: sk2 pro2 cams
is the car tuned for them at all they have a pretty good vtec cross over
Old Mar 8, 2010 | 11:16 AM
EK9 CTR's Avatar
First question: Is this head milled or the blocked decked???
Second question: Is your cam gears setting; E+4, I+2???
Old Mar 8, 2010 | 11:49 AM
Um I don't know about the head being milled I know it has some work done to it. I had the cams setup +4* eh and +2*in and still broke up so I called sk2 and they told me to set it at +4* ex and 0*in. So that's what I did and it idles and runs decent doesn't break up anymore. Just makes no power in vtec witch is expected without a tune. Columbia is going to give a street tune this weekend until he can afford dyno time.
This is not my car it is a buddys that i new to the game
Old Mar 8, 2010 | 12:02 PM
92TypeR's Avatar
FSAE
Do not expect any car with a large cam to run well before tuning.
Pretty dangerous to run it hard without a tune also.
Old Mar 8, 2010 | 01:30 PM
careawholelot's Avatar
this. your just asking for trouble when you put those cams in and hit hella vtec yo before tuning it.
Old Mar 8, 2010 | 04:41 PM
flesh199's Avatar
stock b20 piston??????????with pro 2????
Old Mar 8, 2010 | 05:36 PM
mx621's Avatar
when i first put in my pro2's untuned the car would barley even run at all let alone going out and beating on it. i mean jesus, this is not a type r cam guys, you cant just drop these cams in and run it, they MUST be tuned and installed by someone who knows what they are doing.
Old Mar 9, 2010 | 03:49 AM
Well I have been messing with these cars for awhile I kno what im doing. He just barley engaged vtec to see if it would work. I called sk2 and got all the specs and installed them to sk2s spec. Columbia is going to street tune it tonight until he can afford dyno time.
I know......why put these cams on stock b20 pistons. I tried to tell homeboy that but he didn't listen. I just met him a little bit ago and he thinks he knows what hes talking about be he don't. He plans on building the block. so Thanks h-t and i will tell yall how it runs after the tune
Old Mar 9, 2010 | 11:47 AM
EK9 CTR's Avatar
Those cams were being run at dangerously close with your initial setting for Vtec... Im glad u spread them a bit... A lot of the engine's characteristics changes with these cams, so a good tune is essential to the health of this motor... BTW, what are you guys using to tune??
Old Mar 9, 2010 | 01:50 PM
Um im not sure what columbia is going to use to tune it. Its just getting a street tune to be safe. Should he have to worry about piston to valve clearance with stock b20 pistons? its a gsr head
Old Mar 9, 2010 | 04:05 PM
JDM JEFFREY's Avatar
yes he should..the valve will hit the pistons......
Old Mar 10, 2010 | 02:32 PM
Well got the car tuned ad it was very disappointing did not have to worry about pistons to valve clearance at all Just not enough compression for that big of a cam gonna take them out to he gets more mods and build his spare b20 block
Old Mar 10, 2010 | 10:28 PM
truesrt4's Avatar
love me some skunk2 cams...skunk2 anything is the legit
Tennant
Jan 9, 2011 03:37 PM
T I F O S I
24
Jan 19, 2006 10:48 PM
rdeezy78
Jan 11, 2006 12:05 PM
flat-blk-HB
Jul 13, 2005 04:11 AM
velocitytrends
Apr 29, 2004 04:01 PM
