Quick question about a d16z6 swap.
Hey guys,
I am picking up a full z6 swap today, and i need to know if i need the wiring harness? I will be using my tranny, but i wanna use the z6 intake manifold and p28 ecu. I will be buying a conversion harness to convert my crx to obd1. The only thing the z6 wont come with is the wiring harness, i will need it to hook it up to the crx right?
i have the Z6 wired to my OBDO with stockj harness,,,,,,, if u pick the OBDI one, the plugs wont match (the two plugs that goes into the car harness) , unless u get the whole car harness converision...... if u get the OBDo-OBDI harness conector conversion, u should be abl
e to use ur stock harness.....
[Modified by JDM EF9, 8:46 AM 9/8/2002]
e to use ur stock harness.....[Modified by JDM EF9, 8:46 AM 9/8/2002]
put in the z6 motor and your tranny.get the obd-0 to obd-1 harness.youll need the injector plugs from the z6 motor.i think not sure though,you can use the z6 intake anyway with obd-0.
you dont need the z6 wiring hraness.
use the p28 with the harness 0 to 1
is your car an si and if not you need to do the mpfi swap.
