OmniPower 3 bar MAP sensor calibration trouble
Old Mar 8, 2010 | 05:05 AM
yzracer323's Avatar
Default OmniPower 3 bar MAP sensor calibration trouble
I am trying to install an Omnipower 3 bar MAP sensor and calibrate it using Hondata S300. I went under the MAP and setup for custom setting, I entered 617 for scalar and an offset of 11, as per Omnipower instructions. This results in a rough idle. Is anyone using this current sensor, or experienced any similar problems calibrating a Map sensor? any help is appriciated. by the way this is on a B series engine
Old Mar 8, 2010 | 03:06 PM
yzracer323's Avatar
Default Re: OmniPower 3 bar MAP sensor calibration trouble
i figured it out
Old May 4, 2010 | 04:11 AM
ahthisguyhere's Avatar
what did you do wrong i believe im having the same issue.
Old Jun 2, 2010 | 07:18 PM
Turbozcivic96's Avatar
I also have an omni 3 bar map sensor but i was wondering if you could help me out.
i am running an s200. is it set up the same way an s300 is. im having boost problems around 5500rpm +. it seems like it loses boost/power after 5500rpm. iv narrowed it down to the map sensor. i would really appreciate it if you could help, thanks
Old Jun 3, 2010 | 02:12 AM
yzracer323's Avatar
I had the scalar set incorrectly
Old Jul 3, 2010 | 04:28 PM
hyboost's Avatar
what did you have to set the scalar to?
Old Jul 3, 2010 | 04:42 PM
LightningTeg's Avatar
Community Builder
scalar? Why not just put the max and min mbar readings straight from the manual for it?
Old Jul 5, 2010 | 03:35 PM
blackeg's Avatar
ditto.
im having this same issue on my friends car now. i can get it to run ok on stock map sensor but when i switch over to the omni its not pretty.
Old Jul 5, 2010 | 04:49 PM
madracer's Avatar
Originally Posted by blackeg
ditto.
Hi,
I'm not trying to jack this, but you may want to try this:
Scolar: 838 mbar/volt
Mbar: 31
and under map sensor settings you want to high light the Hondata/Omnipower 4bar.
Good luck and let me know how did that work for you.....
Old Sep 13, 2010 | 06:49 PM
yzracer323's Avatar
Originally Posted by madracer
Hi,
Mbar: 31
Exactly, I set it for the hondata/omni 4bar and it worked perfect.
11psiGSR
Jul 5, 2023 09:36 PM
sdbee84
Jan 31, 2016 11:20 AM
quickchris
Jul 28, 2006 09:47 AM
turbolshatch
Feb 2, 2006 06:06 AM
CiViC SiR
Jul 7, 2003 02:22 PM
