Ok to drive car for a little bit?
Old Mar 7, 2010 | 09:50 PM
stevenDAtegra's Avatar
Default Ok to drive car for a little bit?
I just installed my wideband and watched it as I drove and my ratio varies from 14.2 to around 15.2 basically the whole time under a very small load, basically just driving.
When I do a pull it goes into the 13 range.
I have been reading that 14.7 is what you want to aim for, but on my wideband that reads yellow on the bar.
I'm saving up for tuning software or a tune and will be getting a tune by may or in that month.
I think I am safe to drive it but just wanted to make sure.
The setup is just an ls vtec with p30 pistons, skunk2 intake manifold and a stock b16 head.
I drive about 200 miles a week
Thanks for any input
Old Mar 7, 2010 | 10:14 PM
lyncoors's Avatar
Default Re: Ok to drive car for a little bit?
14.2 to around 15.2 is about normal for idle. what are your mods. na or boosted
Old Mar 7, 2010 | 10:20 PM
It's a pretty simple setup.
The Block has:
*P30 Pistons
*Honda piston rings
*Shotpeened ls rods
*ARP rod bolts
*ACL Bearings
Head just has b17 cams which are close to b16 cams
*Skunk2 intake manifold
*Stock b series head
Everything else is basically stock
Old Mar 7, 2010 | 10:26 PM
lyncoors's Avatar
im not sure what a ideal na afr is
Old Mar 7, 2010 | 10:30 PM
I read this a lot doing research
"Any mixture less than 14.7 to 1 is considered to be a rich mixture, any more than 14.7 to 1 is a lean mixture"
I also read on a site that NA races have their air to fuel ratios set around 14 to 15 because they swap out motors, yet I read 14.7 is what you want to aim for? Maybe they are implying that they have that mixture at WOT?
Thanks for the quick replies by the way lyncoors
My friend got a tune for his ls vtec and at WOT, his AFR was at 12.4. Mine has entered the 12 range on pulls but is generally in the low 13 range
Old Mar 7, 2010 | 10:33 PM
lyncoors's Avatar
you should be fine. id did a quick search and came up with 13:1-13:5 for na at wot
Old Mar 7, 2010 | 10:46 PM
Yeah, I'm gonna try and keep driving to a minimal just in case lol. I wish it was running a little rich compared to a tad lean once in a while, but I guess 15.2 is barely over 14.7.
thanks for the help man!
Old Sep 7, 2010 | 09:54 PM
AzNBrEaKbEaT's Avatar
Sorry for jacking your thread I also have the same problem with mine....it start at 15.7 then to 18.4 then 24.7 then to 28.4 and kit start all over again.also it would be fine some day but other time it blog out and jerk the car real hard and then drive fine when I am not getting on it. I don't know what it is but maybe you guys know what it is...
Old Sep 8, 2010 | 01:55 PM
mouab18c1's Avatar
Your running way lean
sc34dx
Midwest
Apr 25, 2011 01:27 PM
sc34dx
32
Apr 19, 2011 01:34 PM
vinceinside8
Dec 14, 2010 02:06 PM
TheCrimsonGhost666
Dec 19, 2009 06:53 PM
ticivc
Apr 24, 2006 05:58 AM
