removed ventilation system question...
Old Mar 7, 2010 | 08:25 PM
hondapimp125's Avatar
Default removed ventilation system question...
so i removed my all of my a/c,heat,and ventilation system from my del sol, its going to be my summer only car so i have no need for all of that, anyway i'm not sure what to do with my coolant lines that ran into the heater core. do i just loop the lines so it just flows back through the system since there's no heater core?
Old Mar 8, 2010 | 08:40 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: removed ventilation system question...
loop them or you can cap them at the head and the back of the block......
capping it makes it look cleaner.
but looping it keaps the coolant flowing better
Old Mar 8, 2010 | 09:51 AM
Kyle R's Avatar
Just loop the lines.
Old Mar 8, 2010 | 09:25 PM
thanks guys, i was pretty sure i could just loop them but just wanted to double check.
i'd deff feel more comfortable with looping rather than just capping them due to coolant flow, and pressure blowing the caps off.
Old Mar 9, 2010 | 06:02 AM
unusual71's Avatar
when your heater core is set to the full cool position then there is a valve inside that completely closes.
they are used to being "capped" there is not really any reason to loop them.
pressure won't blow the caps off.
Old Mar 9, 2010 | 08:23 AM
I'm not Rick!
^true. i had mine capped and i had a turbo and beat it up...with no problem at all.
autozone caps and cheapy clamps
d16y71999
Feb 25, 2016 04:26 AM
indtegra
Jun 4, 2009 10:36 AM
mortificationrock
24
Aug 11, 2008 11:09 AM
NoVALude
Jul 11, 2006 11:06 AM
