94 civic d15b7 high to low idel
Old Mar 7, 2010 | 07:58 PM
kin6521's Avatar
Default 94 civic d15b7 high to low idel
i have a 94 honda civic hatchback .. it has a d15b7 motor ... the motor was running fine till i changed the intake manifold t a skunk2 proseris intake mani... and now when i first crank it the car runs fine but once it warms up it goes into like a high then low idel ... can anyone help or give me any sugestions ..
Old Mar 7, 2010 | 09:02 PM
Former User's Avatar
Default Re: 94 civic d15b7 high to low idel
Vacuum or intake air leak. Check for a disconnected vacuum hose or a leaking IM or TB gasket.
Old Mar 7, 2010 | 09:06 PM
kin6521's Avatar
alright will check first thing in the morning ... thaks and will let u kno what i find out .. thanks
Old Mar 8, 2010 | 07:30 PM
kin6521's Avatar
i check all that and nothing .. everything is fine any other suggestions
Old Mar 8, 2010 | 09:10 PM
1993eghatchy's Avatar
i had the same issue with the same motor when i first got my hatch..check everything from the TB to ivac make sure everythings where it goes and the bolts r all tourqued down an check the gasket itself if everything else seems fine
Old Mar 9, 2010 | 03:17 AM
ChrisRogers's Avatar
Idle air control valve(IACV) Clean it/replace it and see if that works.
Old Mar 10, 2010 | 04:29 AM
kin6521's Avatar
where is the iacv located wut does it look like
Old Mar 11, 2010 | 12:20 AM
Hope this helps
Old Mar 11, 2010 | 12:27 AM
crxpenguin's Avatar
check the thermo valve under the throttle body if the spring is broke inside it causes a surging idle.
Old Mar 11, 2010 | 10:14 AM
kin6521's Avatar
thanks everyone for the help but i think i got it fixed now .. i replaced the TPS and adjusted timing and got everything straight .. but thanks for the help wid everything everyone ...
Old Mar 11, 2010 | 03:18 PM
Glad I could help and it's great that you got your car running! :D
Old Mar 24, 2010 | 06:42 AM
kin6521's Avatar
does anyone know if i can put a d16 si trans into my car ... i have a d15b8 block wid a d16y8 head .... just want to know if i can put the d16si trans on it before i purchase it
Old Mar 26, 2010 | 09:45 PM
crxpenguin's Avatar
good to hear you got your car up and running again
hun8504
Dec 26, 2012 09:37 AM
singlecammin
Jan 20, 2011 07:20 PM
Roofrack
Apr 7, 2009 07:42 PM
ludacole
Aug 29, 2004 03:38 PM
extrmeboost
Mar 18, 2003 09:36 PM
