ARP Rod bolts, LS/VTEC
Old Mar 7, 2010 | 05:33 PM
turb0teg's Avatar
Default ARP Rod bolts, LS/VTEC
Two friends of mine have told me 2 different things concerning the installation of ARP rod bolts into my stock ls/vtec (GSR head). It's only being revved out to 7500 rpms at the moment, but I'd like to be able to safely rev higher (probably 8200-8500). I'm told by one friend that I can simply pull the pan, remove the stock rods bolts 1 at a time, and replace with the ARP. Another friend is telling me I'll have to measure the bearing clearances w/the ARP and install new bearings accordingly. The first friend has built quite a few successful ls/vtecs, but the second friend has put some doubt in my mind of the simplicity of the change. Honda-tech's verdict?
Old Mar 7, 2010 | 08:47 PM
nsxter's Avatar
Default Re: ARP Rod bolts, LS/VTEC
well arp says you need to have the big end of the rod re-sized when you install there rod bolts reason is it will egg shape the big end of the rod when you torque the bolts down to spec
Old Apr 25, 2010 | 02:07 PM
gutted-dx's Avatar
Wondering the same thing, is that on ARPs website?
Old Apr 28, 2010 | 05:27 PM
NJIN BUILDR's Avatar
The correct way,with out a doubt is to resize the rods after installing ARP bolts.But many people have done it without resizing without catastrophic results.
But the whole ls rod bolt thing is little overdone anyway,they are not that bad.The rods themselves are not that strong.Put them next to a gsr rod and you will see what I mean.
2ndchirp
Jun 20, 2024 01:15 PM
turbolshatch
Jan 21, 2006 09:55 AM
Speed94
Jun 30, 2005 08:04 PM
Wazup
Mar 31, 2005 02:58 PM
FastFoot
Sep 28, 2002 12:09 AM
