swapping rods and cranks gsr ls etc..
Old Mar 7, 2010 | 04:52 PM
x_doug-x's Avatar
Default swapping rods and cranks gsr ls etc..
trying to get some information here. i just spun a bearing in my gsr. i ordered a bunch of crap to boost it but i dunno if i'm going too.
anyways, my question is, is there a diffrence between gsr and ls rods? are they interchangable? i hear you can use the LS crank and it has a longer stroke than the gsr and creates a little bit of a stroker? would this perform ok with type R pistons and would you be able to use them? i also read that the type r pistons bumped up the compression..
basically i'm wanting to know what is and isn't usable. i'm trying to put this back together on a budget and will prob. buy used rods
also, are the b16 and gsr rods the same?
Old Mar 7, 2010 | 05:07 PM
x_doug-x's Avatar
Default Re: swapping rods and cranks gsr ls etc..
or what about putting a whole ls rotating assembly in a gsr?
Old Mar 8, 2010 | 05:28 PM
x_doug-x's Avatar
wheres all the techs? i bought a ls crank and ls rods, and i'm going to use my original pistons and rings just to put this thing back together. my question now is, the piston is going to move farther up and down in the cylinder. does this mean it needs honed again, or possibly bored?
Old Mar 8, 2010 | 05:51 PM
newtron63h's Avatar
from what ive heard LS and GSR crank ARE NOT intechangable.....as for rods i have no idea.
anyone correct me if im wrong.
Old Mar 8, 2010 | 05:55 PM
jdmwannabee's Avatar
ls crank and rods in a gsr, you would have to remove the oil squirters and i believe your compression would be bumped up.
Old Mar 8, 2010 | 06:31 PM
x_doug-x's Avatar
i'm gonna try to bend the squirters out of the way, i have read you can do that as well. i already bought the LS crank and rods , i just gotta know for sure if i can use the gsr pistons, and also need to know if i'm gonna have to hone the cylinders or not. i'm going to stick with the rings i already have and pistons, the motor has been rebuilt already, i dunno how long ago it was that way when i got it, i can see numbers engraved on the rods and hone marks on the cylinders.
turbodelsolb16a2
Feb 7, 2010 07:57 AM
dirtyharryhatch
10
Jul 21, 2009 02:43 PM
grand champ
Feb 20, 2008 10:10 AM
svmnredracr
Sep 28, 2004 07:46 AM
advanracing62
Oct 11, 2003 09:57 PM
