Transmission & Drivetrain Gearboxes, Differentials, Clutches
comp. clutch stage 5 kit, tranny cant get into gears @ high rpm
Old Mar 7, 2010 | 11:52 AM
092eg6's Avatar
Default comp. clutch stage 5 kit, tranny cant get into gears @ high rpm
I have a competition clutch stage 5 kit in my 95 honda civic B-series motor with a hydro transmission, Im running into a problem, so im looking to see if u guys can help me out..... My transmission is in good working order on my daily driven stock gsr motor with stock flywheel/pressure plate and a ACT 6 puck disc, it drives and shifts smooth at any rpm. So then i use my transmission onto a built 95mm stroker b series motor with the competition stage 5 clutch kit with a 8lb. flywheel and now it does not let me get into gears any thing over 7k rpm, seems like the clutch is engaging at 7K rpm even if the clutch pedal is fully pressed down to the floor, I also notice that when i put it in first gear while my feet is fully pressed onto the clutch pedal and rev up the motor to launch the car, it tends to pull forward after the rpm reaches 7k ..... also the clutch won't disengage when I step on the clutch pedal at high rpms to shift, so i cant get into any gears at high rpms while racing... please help me out.........
Old Mar 7, 2010 | 06:48 PM
092eg6's Avatar
Default Re: comp. clutch stage 5 kit, tranny cant get into gears @ high rpm
anyone?
Old Mar 8, 2010 | 04:18 PM
092eg6's Avatar
i guess no one wants to help me
Old Mar 9, 2010 | 02:31 PM
092eg6's Avatar
damn nobody ever have this problem with aftermarket clutches??
Old Mar 10, 2010 | 05:24 AM
97_b18c1's Avatar
TRIAL USER
https://honda-tech.com/forums/forced-induction-16/competition-clutch-problem-fi-integra-2660616/
A few people including myself have had the same problem. I adjusted the free play (lengthened the rod) and it shifts fine now.
Old Mar 10, 2010 | 11:40 AM
092eg6's Avatar
Originally Posted by 97_b18c1
https://honda-tech.com/forums/showthread.php?t=2660616
ok, got a new clutch master cylinder and adjusted the rod, engagement/disengagement point is up higher than before, have less than 1inch of freeplay from the top, seems like evverything is fine but still i can't get in gear at high rpms!!!!!!
Old Mar 12, 2010 | 12:10 PM
fly_high_gsr's Avatar
your pressure plate bad
Old Mar 12, 2010 | 03:10 PM
092eg6's Avatar
please elaborate!
Old Mar 12, 2010 | 05:20 PM
LowBudgetBEe's Avatar
your pressure plate is broken. cc clutch stage 5 sucks. my friend just broke one at the track doing a burnout. get exedy or act. exedy is the only single disc clutch that i never had a problem with.
Old Mar 12, 2010 | 07:39 PM
092eg6's Avatar
how is that so that my pp is already broken? ***** only got like 50 miles on it
was your friend having high rpm lockout like me?
it still drives and shifts fine, just cant get in gears at high rpm.
Old Mar 13, 2010 | 10:08 AM
unless you got defective pressure plate only thing engaged and disengaged the clutch or your syncrho's and slider going bad not synchronize when you shifting on high rpm
Old Apr 22, 2010 | 05:58 AM
rash's Avatar
I'm having the same exact issue as the OP. It's with a stage 3 CC kit though. It seems Competition Clutch is either having issues with their manufacturing process, or they're intentionally producing kits that require the use of their custom stepped flywheels...
It's no coincidence that everyone with Comp Clutch kits are having the exact same problem! I sent my kit back to CC and was told I need to buy their flywheel, because there is nothing wrong with the kit. That sounds like shady business tactics to me. Why would buying their flywheel fix the issue, unless they're changing the stepping requirement on your clutch kits?
If this stepping requirement is indeed true, it MUST be advertised on their website.
We all need to get together and fight this.
blkbb6
Dec 8, 2011 04:39 AM
b20vtech
32
Oct 28, 2011 05:01 PM
95_red_dc
13
Nov 10, 2008 03:16 PM
johnqt3
Sep 14, 2005 02:57 PM
