Tranny making noise???
Old Mar 6, 2010 | 04:55 PM
MrExclusive's Avatar
Default Tranny making noise???
Well im not sure if its really the tranny but I believe so because of this explaination.
When I drive the car or have it standing still I hear this clicking sound(no its not a knock. I know a knock sound when I hear it) coming from the engine bay. It doesnt sound like a bad omfg noooo kind of click but how would I know anyways. It is annoying though when im not listening to music. My reason the believe its coming from the tranny is because I just recently found out that the sound goes away EVERY single time I press the clutch in. What is up with that??? Car is a 95 DX stock motor if it helps.
Does anyone happen to know what the issue may be??? Trans mount maybe???
Old Mar 6, 2010 | 06:37 PM
Default Re: Tranny making noise???
I would try to describe more in detail later on when I get a chance however I dont think it would make much of a difference cause I can barely describe it now. If i can pick the sound up on vid I will post it.
Old Mar 6, 2010 | 08:27 PM
92B20's Avatar
maybe bad throw-out bearing in the clutch..since u say it goes away when u press the clutch in..
Old Mar 6, 2010 | 09:34 PM
94dc's Avatar
^^^thats what i was thinkin its probably your throw out bearing..& its a pretty common thing on stock egs,well to me atleast
Old Mar 6, 2010 | 09:52 PM
majrneo's Avatar
shouldn't it be the other way around, when the clutch pedal is pressed the TOB makes the noise?
Old Mar 6, 2010 | 10:01 PM
thabadguy's Avatar
I.S.B.
Input Shaft Bearing
Old Mar 7, 2010 | 03:18 PM
96honda_EK's Avatar
Yeah i had that problem with my 95 eg also. I changed my tranny and it was all good but if you dont wanna do that then its your throw out bearing
Old Mar 8, 2010 | 07:34 AM
Ok im assuming that by you all saying throw out bearing you all mean release bearing right??? And if so I just recently swapped the tranny for one in better condition and changed that bearing along with every other bearing and seal as well.
When I swapped the tranny the sound wasnt there until honestly now that I remember I carried the car to get aligned and then all of a sudden there is this sound now.
However I checked everything that could possibly have to do with suspension. I have a bad wheel bearing but other than that I cant see anything that would make that kind of noise related to suspension and what would it have to do with it the sound going away when the clutch is pressed in.
Just thought I would post that extra info. I would check the bearing if I have to but rather not have to go there right now.
Old Mar 8, 2010 | 08:32 AM
lome1232's Avatar
Change your trans oil sometimes that helps to determine the problem if the noise reduces then its probably your barings. trans bearings.
a trans mount wont cause this a clicking noise.
I have a 95 LX manual trans and had the exact same problem. When i stepped on teh clutch the noise went away, when i i would take off in first i would hear it at low rpm,. and once i went to high rpm it would be gone, and the biggining of second i could hear it again, and so on up until third i starte4d hearing it about four months after i first heard it wheni was in neutral.
I bought a bearing kit for about 160 dollars and just swapped my bearings easy **** if you know what you are doing. i would get it done professionally if you dont have that experience.
Those transmissions are super strong, unless you add some extra power it will withstand the power that engine will provide, i beat up my civic its stock with intake/headers/exhaust. I have 213xxx miles on it and it purs like a baby. Im about 99 percent sure its your bearings if you hear what i described. Good Luck
Old Mar 8, 2010 | 08:37 AM
civicb16eg's Avatar
Originally Posted by thabadguy
I.S.B.
Input Shaft Bearing
x2
Old Mar 8, 2010 | 08:40 AM
You know what...you couldnt have described it any better. That is exactly how the car is operating. I guess I will pull it down this weekend look at it and change it out again. I still find it weird though the bearing and seals is not even a month old from the dealership.
Old Mar 8, 2010 | 09:44 AM
lome1232's Avatar
Im talking about the internal bearings of the transmission, I dont think it will be your throw out bearing. i believe there are about four or five bearings needed to be changed. If you call up a transmission shop in your area and ask them for a bearing kit for your DX. It also comes with the new seals.
For my friends car i dropped the trans and just took it to a trans shop and they rebuilt it with just new bearings and seals and its running strong. I did the bearings and seals in my own car and it is also running strong.
They are going to want to sell you syncros and you most likely do not need them, I have never seen a manual 92-95 civic trans have bad syncros or anything other then just needing bearings.
What did the dealership do to the trans other than seals?
Old Mar 8, 2010 | 07:10 PM
jtho2345's Avatar
TRIAL USER
i have a 95 civic all stock i just did the clutch and pressure plate and after all that i had one of the drive axle on the passenger side pop out. and now there is a sound like a tool rattling around in the tranny. whats the noise and how did the drive axle pop out when i went to drive it.
Old Mar 8, 2010 | 10:47 PM
lome1232's Avatar
did the trans sit smoothly when you put it back together? Honda OEM Clutch? I have seen it where people dont completely put the axle in the trans and when you go to drive it its not spinning smoothly and will pop out, also have you dont CV boots lately, you might not have enough grease in there.
You have to be more specific with when the noise occurs, under what conditions.
Old Mar 9, 2010 | 12:21 AM
chewyv's Avatar
pm4nudes
i wonder how many hours of labor a place will charge ya to replace the bearings...
Old Mar 9, 2010 | 08:23 AM
lome1232's Avatar
It depends, if you take the tranny in, or you take the car in and have them drop the tranny, Down here in So Cal they charge about 5 bills, if you drop the tranny its about 350. Thats what i was quoted two years ago. By a transmission shop.
Old Mar 9, 2010 | 08:49 AM
A better description of how it sounds is like back in the days when you have a bicycle and you put a crushed soda can on the back tire to give it that deep sound. It sounds similar to that but a little lighter for those who ever did that back in the days
Ch3vy3ater
Jun 19, 2008 07:38 PM
SkIp_Civic_Ek6
Mar 19, 2007 12:06 AM
sleepy_hatch
Sep 28, 2005 05:29 AM
dominate9
Oct 24, 2003 09:41 AM
aNaRcHyiNmYeK
Mar 8, 2002 06:01 AM
