99 civic si won't start...
Old Mar 6, 2010 | 06:00 AM
pinoyboy204's Avatar
Default 99 civic si won't start...
hey guys. i have a 99 civic si/ex (canadian model) 5spd that won't start. i bought it used and not running to begin with and i found that the thermostat ground was loose, tightened it up and now the car will crank over but will not start or has a hard time starting. these are the following things i have checked and replaced...
ecu
map sensor
main relay
compression checked 170psi all cylinders
ignition checked and spark is good
fuel pressure checked
what could be the problem?? i've tried holding my foot to the gas pedal and pumping it...almost wants to start but doesn't. i checked the plugs and they are wet with fuel, so probably my injectors are good. no CEL. maybe bad gas, bad fuel filter?? or bad crank sensor?
Old Mar 6, 2010 | 06:27 AM
Former User's Avatar
Default Re: 99 civic si won't start...
What color is spark at the plugs? If it's bright white, check the mechanical timing because the timing belt may have slipped.
Old Mar 6, 2010 | 08:53 AM
they are brown, but will double check. any other suggestions guys? i'll try and swap out another distributor, i doubt that is the problem..
Old Mar 6, 2010 | 09:06 AM
300whpej's Avatar
dont hold the gas pedal
Old Mar 6, 2010 | 09:37 AM
Spark should be bright white. If not, the coil inside the distributor is likely bad.
Old Mar 6, 2010 | 03:24 PM
update: replaced fuel pressure regulator, injectors and fuel filter no change. the only way i get the engine to turn over is if i hold the gas pedal to the floor because the engine was flooded.
Old Mar 6, 2010 | 03:41 PM
canadaek's Avatar
if you have fuel -spark - and good compession it's got to be timing - you should never need to pump the gas in a fuel injected engine holding it to the floor puts it it clear flood mode and stops fireing the injectors pull the top cover off and check the t-belt also look at the rotor inside the dizzy i have seen them melt and spin on the shaft (bad dizzy bearing) and the spark plug wire;s are on right
Old Mar 7, 2010 | 07:12 PM
update: i changed the crank sensor and checked cam timing and crank timing mark and its bang on. no change. still cranks over but doesn't start...i'll try and change the distributor tomorrow...
Old Mar 7, 2010 | 07:29 PM
noremorseracing's Avatar
change the plugs, if thats not it check timing.... if the plugs are wet they wont work for ****.. i had the same prob on my h22 and it fired rite up ... start simple
Old Mar 8, 2010 | 07:52 AM
update: runs of quick start fluid, while i disconnected the injectors, maybe bad gas as it floods the engine...
Old Mar 8, 2010 | 09:21 AM
With the key in ON(II), is there battery voltage at the injector clips?
Old Mar 8, 2010 | 11:22 AM
checked with a test light, shows continuity when cranked.
Old Mar 8, 2010 | 11:30 AM
A node tester can be used to check whether each of the injectors pulse when the engine is cranked. If not, the problem may be the ECU or a bad ECU ground wire.
Old Mar 8, 2010 | 01:28 PM
i've swapped different ECU no luck. i've also bolted the ecu down to the body, no change. can a bad headgasket be the culprit even though i have good compression??
Old Mar 8, 2010 | 04:25 PM
go spend 10 bux on plugs and see what it does
Old Mar 8, 2010 | 04:39 PM
kenny24's Avatar
so you checked the timing?? just swapping parts is not gonna help you learn how to diagnos a car.
Old Mar 8, 2010 | 04:45 PM
read no0b. i've checked timing and its bang on.
i've had 3 different sets of plugs one of the set being brand new...
i think it could be a bad fuel pump not providing enough fuel pressure causing the injectors to not atomize and spray correctly.
Old Mar 8, 2010 | 05:06 PM
b18c_Ek101's Avatar
i don't think fuel is the problem try changing the cap and rotor or the dizzy entirely. d-series are know for the dizzy's to go
Old Mar 8, 2010 | 05:26 PM
i'll try a new distributor tomorrow and also a working gsr fuel pump.......hope it helps...
Old Mar 9, 2010 | 09:47 AM
changed distributor with working coil and working fuel pump...no change...there is gas in the oil pan....
BlackLX
22
Aug 18, 2013 07:55 PM
redsidriver
23
Oct 26, 2011 05:24 AM
dc2doi
Jan 6, 2008 01:43 PM
qcoffey
Dec 31, 2002 09:57 PM
dsmith817
Nov 2, 2002 07:17 AM
