Possible to still have spark with bad igniter?
Just as the topic says. Is it possible to have a bad igniter and still have spark. My '99 Si won't start. I've checked for fuel and that is present(have a fuel pressure guage), I've checked for spark and that is present(not a bright blue color, kind of orange) and the timing is OK I had the belt changed less than 20k ago. The car has been running perfect. I was just waiting my turn to go into the car wash and when I went to start the car it wouldn't fire up. It will try to start but immediately die. Any help would be greatly appreciated.
Re: Possible to still have spark with bad igniter? (qcoffey)
My ignitor was on its last legs and sometimes would die, but I could get it started and running every once in a while. It was also dependent on the weather, like in rainy weather it wouldn't even have sparked but in hot dry weather it would run. Once I replaced it no more problems.
As stated above, igniters usually either work, or they don't. A weak spark usually indicates a coil problem. Some igniters fail when they get hot. The car runs for a while, but when the igniter reaches a certain temperature, it stalls and won't restart. After the car cools down, it will restart.
quad
20
03-14-2007 05:16 AM
