Rear brake disc question
Old Mar 5, 2010 | 12:42 PM
92B20's Avatar
Default Rear brake disc question
so today just for the hell of it i wanted to see how hot the brake discs were, since i had just got home after driving around. I was on curvy roads so i used the brakes quit a bit. Anyway i went to feel the rear brakes and they were cold, just barley even warm..Both of them were like this. The front rotors were Hot they way they should be.
Any ideas to way this could be.
My car is a 92 civic VX and has 2000 Civic Si brake conversion.I just noticed this today so i haven't tired anything yet..
BTW the car brakes good but the steering wheel shakes when hard braking, like when getting off the freeway or going down a hill.
Old Mar 5, 2010 | 12:47 PM
Red_Army's Avatar
Default Re: Rear brake disc question
because you only do about 30% of your entire braking on your back brakes.
that conversion besides for ease of changing and looks isn't worth it. you wont get anymore if not less braking power from discs in the rear without 2/4 puck calipers, SS brake lines and whatnot.
so id say its working as it should. cept for that hard braking.
Old Mar 5, 2010 | 12:54 PM
RotaryPWR's Avatar
that vibrating during hard braking sounds like warped rotors. you can either replace them with new ones or get them machined..from my experience, replacing them is way cheaper if you can do it yourself (very simple job)!!
Old Mar 5, 2010 | 01:04 PM
92B20's Avatar
yea i figured the rotors might be warped. Since they look like crappy ebay drilled rotors. and yea i can replace them myself.
Old Mar 5, 2010 | 01:14 PM
98civdx's Avatar
Master Detailer
sounds normall your front do way more braking then rear. yes get rid of those crappy ebay brakes, possibly do pads also.
Old Mar 5, 2010 | 02:41 PM
fastrxu's Avatar
Perfectly fine also do u have steelies or wheels with big gaps between each spoke?
Old Mar 5, 2010 | 06:25 PM
92B20's Avatar
yea im planing on buying new front rotors, but gotta wait until next pay check..And i have 15'' rota C8s.
Old Mar 6, 2010 | 07:06 AM
Red_Army's Avatar
also next time don't get drilled rotors. at best get slotted. drilled on a DD are well known for cracking.
Old Mar 6, 2010 | 04:16 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Don't even get slotted. Get blanks. OEM, Brembo, Wagner, there are lots of others ... or even better, something not made in China. Consider buying North American.
Old Mar 6, 2010 | 05:06 PM
Blahblah718293's Avatar
but before you even do that, loosen the lug nuts on the front and torque them properly. if that doesnt help, THEN buy new rotors.
youd be supprised how much uneven wheel torque can pulsate the brakes.
Old Mar 6, 2010 | 05:26 PM
deschlong's Avatar
Loved
Community Favorite
^ Excellent point.
Old Mar 6, 2010 | 08:31 PM
92B20's Avatar
nice ill do that first. good idea, yea when i said i was planing on getting new ones i had brembo blanks in mind. also maybe some Hawk pads if i have enough left over
Old Mar 7, 2010 | 05:28 AM
JDW's Avatar
JDW
are the back brakes working at all? May be the bias controll
Old Mar 7, 2010 | 10:35 AM
crazybeanery0's Avatar
I just changed out my rear disc rotors and pads. I bought Duralast for both from Autozone. Limited life time warranty on the pads and two year warranty on the rotors. Can't go wrong with that, especially for a dd like mine!
Old Mar 7, 2010 | 05:07 PM
98civdx's Avatar
Master Detailer
go to shucks spend 25 30 bucks per rotor, no need for slotted or drilled
Old Apr 24, 2010 | 07:09 PM
murdered sol's Avatar
did you upgrade the master cylinder/brake booster when you upgraded the brakes? if you don't get a bigger master cylinder to push more fluid(which is what you need for disc brakes), then your "upgraded" brakes aren't going to do much
Old Apr 24, 2010 | 08:40 PM
SoFresh1189's Avatar
also dont forget to change the brake proportioning valve. drum brakes have less brake fluid going to them. with a proportioning valve from a 4 wheel disc car its like 50/50 between front and rear calipers
redturds
Honda Civic (2001 - 2005)
Sep 19, 2016 06:47 AM
B18cFreak
Dec 15, 2007 12:46 PM
B18C_EJ8
May 19, 2004 02:48 PM
mickey513
Oct 2, 2003 04:35 AM
AllShwNoGo
Mar 6, 2002 08:57 PM
