Worried: excessive blowby but good tests what gives?
Old Mar 4, 2010 | 09:09 PM
accord99power's Avatar
Default Worried: excessive blowby but good tests what gives?
Setup in signature. So i have excessive blow by and oil blowin out the intake port of the valve cover. Its not to bad but noticable, and when oil cap is off you can feel the blow by for sure. Heres what i dont get 1) Vacuum is at solid 20 on idle 2) Compression test at 215 across the board. any idea guys?
Old Mar 5, 2010 | 05:02 AM
Alfa Turbo's Avatar
Default Re: Worried: excessive blowby but good tests what gives?
How do you know it is excessive? Any running engine will create a "breeze" just from the crank and pistons moving around. Flap your arms around without making the air move.
Also, water is a by product of combustion. It gets in the oil and when the oil gets hot enough it escapes as water vapor. Depending on the atmospheric conditions it can look excessive too.
If you are confident with your compression tests drop your worry.
Cheers.
Old Mar 5, 2010 | 05:28 AM
92redhatch's Avatar
Do you have a catch can setup?
Old Mar 5, 2010 | 05:40 AM
PrecisionPerformanceParts's Avatar
Do a leak down test.
Old Mar 5, 2010 | 05:43 AM
sorry about this post, i posted it before i read my last thread, my catch can is installed wrong.
protopro88
Aug 24, 2012 03:22 PM
jcskyhigh
Jul 25, 2007 01:24 PM
bennyhonda7
May 17, 2005 07:46 AM
LSVTEC 91 Civic
Mar 28, 2005 08:27 AM
Witty
Aug 15, 2003 09:05 AM
