IL Built n Boosted 96 Hatch Silverstone Metallic!
Old Mar 4, 2010 | 05:11 PM
Pony_Fed95's Avatar
Default Built n Boosted 96 Hatch Sebring Silver!!! Tilton/spoon/GE/Skunk2
PRICE DROP!!! $8000!!!! NEED THIS GONE!
Ok... Car is currently in STL but could be shipped to me(Texas) or anywhere for that matter for a cheap price.
I have owned this car for 3 years now and I've put alot of blood sweat and tears into it. I have built it with the best part you can buy. Im in the Air Force now and want to start on a new project when I get to my first base. Here we go!
1996 Honda Civic CX
Engine:
Tuned with Crome
Complet Wire tuck
+++Block+++
-All Golden eagle bolts
-B16 with Golden Eagle HD sleeves
-Golden Eagle Block gaurd(for extra strength)
-Bored to 81mm
-CP Pistons
-Total seal rings
-Eagle H-Beam rods
-Type R oil pump
-Stock crank polished,knife edged and balanced.
+++HEAD+++
-Ported B16 head
-Hitech Cam Tower Girdle with ARP Hardware
-ARP head studs
-Skunk2 Tuner Stage 1 cams
-Skunk2 Cam gears
-Skunk2 Valves
-Supertech Duel valve springs
-titainium retainers
-JG Edlebrock turbo Intake Manifold
-JG Edlebrock Throttle body
-880cc Injectors
-MSD B-Series Vtec FULL distributer with external blaster coil.
-MSD wires
-Custome hand painted "Jessica Rabbit" valve cover
--Earls AN oil fittings welded in and stainless steel braided lines for catch can.
-AEM Fuel rail
-AEM FPR
-All custom steal braided fuel lines with Earls fittings.
++SOLID MOTOR MOUNTS
+++TURBO SETUP+++
-Peak boost kit with Ram horn manifold.
-Heat coated
-BRAND new Precision SC6162S turbo(from new billet series)-replaced the old 57 trim
-Custom Fabricated 3 inch down pipe all tig welded
-3 Inch mandrel bent midsection to Thermal 3 Inch rear section.
-V-Band clamped
-Tial 48mm Wastgate
-Tial BOV
-Huge Front mount intercooler
-All hard pipes are powder coated silver
-Custom fabricated oil box with Earls fitting and steel braided lines
+++Transmission+++
-GSR Tranny
-Quaffe LSD
-All new parts
-Cryo treated gears
-ITR final drive
-Tilton Twin Disc Clutch and flywheel
-Gator Racing axles
-JDM ITR shifter
+++Body/Exterior+++
-Silverstone Metallic paint job from S2000
--all side moldings painted as well
-Black housing headlights
-HID lighting system with high beams and low beams
-Painted Spoon style mirrors
-Mugen style Grill(painted)
+++Suspension/Wheels+++
-Car now has 15 inch Rota GT3 wheels with brand new tires
-Ground Control coilovers
--Custom spring rates for drag racing
-KYB AGX 10 way adjustable shocks all the way around
-Skunk2 upper control arms
-Skunk2 camber kit
-CTR sway bars
-Stiff bushing kit
+++Interior+++
-Greddy Profec-b II and Greddy Turbo timer
-+Custom fitted into driver side air vent
In-Cluster Gauge pod
-AEM EUGO Gauge wideband
-Autometer Boost gauge
-Mint condition Civic SI gauge cluster
-Real Mugen pedal covers
-Real CTR shift boot
-Real Spoon Shift ****
-Various carbon fiber wrapped pieces
-OEM Honda Radio
-Comes with JDM radio block plate
-6 Point cage(Not installed but can be included for extra with G-Force racing Harness)
I'm sure I left some things out, but thats all I can think of at the moment.
+++Little background+++
This is a new setup on this car and hasnt been tuned yet. New Turbo, intercooler, cams, cam gears. On the old setup with the tiny Garret 57 trim and stock cams the car made 326whp on pump gas and 453whp on race gas. The car is getting tuned this week, just for a mild pump gas tune. Probably 15psi = 350ish whp. This car is VERY fast. It was built with the best of the best parts. The motor is built to handle whatever you throw at it. With this setup the car is capable of making 700+whp with race gas or E85!!!! The motor and trans only have 1500 miles on them at most. For lack of better wording... this car is Stupid Fast! There is TONS of money in this car. I had it appraised for fair market value, incase a loan is needed, and it appraised at $15,000. All paperwork can be given up request. Please call me or text me with any questions!
$8000!!!!!!!
SERIOUS INQUIRES ONLY PLEASE!! NO TRADES!!!
Call or text anytime.
618-789-2278
Andy
OR Ben
618-334-1321
http://i7.photobucket.com/albums/y25...n/IMG_1970.jpg
http://i7.photobucket.com/albums/y25...n/IMG_1977.jpg
These wheels are no longer on the car.
http://i7.photobucket.com/albums/y25...n/IMG_1980.jpg
http://i7.photobucket.com/albums/y25...n/IMG_1972.jpg
http://i7.photobucket.com/albums/y25...n/DSC00087.jpg
http://i7.photobucket.com/albums/y25...n/DSC00082.jpg
http://i7.photobucket.com/albums/y25...n/DSC00081.jpg
http://i7.photobucket.com/albums/y25...n/DSC00079.jpg
Just after paint
http://i7.photobucket.com/albums/y25...rringpaint.jpg
http://i7.photobucket.com/albums/y25...naturecopy.jpg
Last edited by Pony_Fed95; Mar 11, 2010 at 09:36 AM. Reason: To get more responses
Old Mar 4, 2010 | 09:32 PM
srt4mike's Avatar
Default Re: Built n Boosted 96 Hatch Silverstone Metallic!
Bump for boost!
Old Mar 5, 2010 | 06:25 AM
Pony_Fed95's Avatar
bump!
Old Mar 5, 2010 | 08:59 AM
turbo24's Avatar
I will get in contact with you when i get home bro.
Old Mar 5, 2010 | 09:03 AM
Pony_Fed95's Avatar
Sounds good. When will that be? Where is home?
Old Mar 6, 2010 | 09:48 AM
Pony_Fed95's Avatar
Bump! Make some offers!
Old Mar 6, 2010 | 10:43 AM
ghostofnyc's Avatar
nice car glws
Old Mar 6, 2010 | 03:02 PM
KARSON's Avatar
bump
Old Mar 6, 2010 | 03:56 PM
mugentuner97's Avatar
what color are the gt3's?
Old Mar 7, 2010 | 10:36 AM
Pony_Fed95's Avatar
gunmetal
bump
Old Mar 8, 2010 | 08:11 AM
Pony_Fed95's Avatar
BUMP $8800 obo!!! NEED THIS GONE!
Old Mar 9, 2010 | 10:17 AM
Pony_Fed95's Avatar
BUMP FOR $8200!!!!!!!!! Found a car I want, need it gone asap!
Old Mar 9, 2010 | 04:01 PM
Pony_Fed95's Avatar
Bump! Nobody wants a clean built hatch?
Old Mar 10, 2010 | 07:33 AM
Pony_Fed95's Avatar
BUMPO!!! NEED THIS GONE!!!!!!
Old Mar 11, 2010 | 09:37 AM
Pony_Fed95's Avatar
Bump! Price drop to $8000! I need this car gone!!!! Somebody has to want a Clean, built right hatch!!!!
Old Mar 11, 2010 | 12:01 PM
Pony_Fed95's Avatar
ttt
Old Mar 11, 2010 | 12:12 PM
nightowl's Avatar
texed andy.
Old Mar 12, 2010 | 07:49 AM
Pony_Fed95's Avatar
Bump! Lots of interest, but still for sale!!!!
Old Mar 15, 2010 | 08:35 AM
Pony_Fed95's Avatar
Getting tuned tomorrow! BUMP!
ej1_civic
47
Dec 27, 2016 10:13 PM
BradtheMachine_Si
45
Aug 23, 2011 02:13 PM
cyrus_gremlins
Aug 9, 2010 11:55 PM
iheartintegras
Feb 14, 2007 05:21 AM
92 CIVIC HATCH VX
Jul 19, 2006 08:29 AM
