PLEASE Help NO Fuel PRessure
Old Sep 7, 2002 | 07:44 PM
hwnstyle21's Avatar
Default PLEASE Help NO Fuel PRessure
Okay here is the deal. I have an EG w/ a JDM H22A motor. The thing is there's no Fuel pressure. When U turn the key ur suppose to hear the fuel flow but I don't hear crap. I have an AEM fuel Rail and adj. regultor. The fuel pressure guage doesn't even move when I try to start the car. YES I do have gas in the car. I just changed the Fuel pump and still no pressure. If anyone know's what the problem could be please help me. Thanks
Old Sep 7, 2002 | 09:28 PM
raene's Avatar
Default Re: PLEASE Help NO Fuel PRessure (hwnstyle21)
Is the pump getting power? Check that 1st. 2nd, if it is, try pulling off a fuel feed line and putting it in a bottle, then priming the pump. If it squirts, come back for more answers.
Old Sep 7, 2002 | 10:02 PM
Leb_CRX's Avatar
it's a fuse...unless you checked them than that's out
I had one go on my CRX, couldnt' figure it out for 3 days, turns out some non-mattering fuse went...somethin that shouldn't render a car unstartable, but it did,fuel pump you couldn't hear, but still had spark
|eb_CRX
Old Sep 8, 2002 | 02:14 AM
ill phil's Avatar
Default Re: PLEASE Help NO Fuel PRessure (Leb_CRX)
If you have DMM (digital multi meter) you can check and see if you are getting power to the fuel pump. If not could be voltage drop somewhere in the wiring due to poor ground or blown fuse. Check and see if you are getting power to the fuel pump
subie22
Oct 7, 2009 01:09 PM
hlau2o9
Dec 11, 2008 09:19 PM
iNetForce
Nov 13, 2005 08:27 PM
VNTEC
Jul 6, 2004 06:45 AM
oneslowcivic
Sep 19, 2003 08:02 PM
