lucas 80w 90 gear oil for a d16z6??
Old Mar 4, 2010 | 11:44 AM
mikej94civex's Avatar
Default lucas 80w 90 gear oil for a d16z6??
i know there are numerous threads about gear oil, but i got a very
simple question, i'm changing my tranny tomarrow night and want to
know if the lucas 80w 90 is a good or bad idea...it's 6.99 a qt
so it's cheap plus lucas is known to be a name to trust, thanks!!
Old Mar 4, 2010 | 11:55 AM
Default Re: lucas 80w 90 gear oil for a d16z6??
also i was considering vavoline 75w-90.......
Old Mar 4, 2010 | 11:59 AM
es01civy's Avatar
should be fine. I was use the stuff with syncromesh and never had any problems
Old Mar 4, 2010 | 12:04 PM
EE_Chris's Avatar
It's a bad idea when you could instead run geniune Honda MTF, which also costs less.
Old Mar 4, 2010 | 12:10 PM
300whpej's Avatar
its a penny less than honda MTF from my local dealer, but i dont think it will hurt. the penzoil with syncromesh is what ive heard people use.
Old Mar 4, 2010 | 12:12 PM
newtron63h's Avatar
use MTF............if it aint broke dont fix it.
Old Mar 4, 2010 | 01:04 PM
thanks everyone, but pennzoil syncromesh is for gm/chrysler i hear...also honda mtf isn't available near where
i live, and the closest honda dealer is a 20 minute drive, and considering i'm walking that's outta my range lol. I'm just
goin to get the 75w-90 valvoline from autozone last question, how many qts would i need to buy?
Old Mar 4, 2010 | 01:10 PM
BryanM.'s Avatar
Resident Gearhead
75w90 is WAY too thick.
Before Honda designed their own manual transmission oil, they used regular 10w30 (last page of the '92 Civic Owners Manual says 10w40 is fine too).
Of course, this is before the developed their own MTF, which is the best oil to use because it is DESIGNED for thier transmissions ('96 Civic Owners Manual states that 10w30 or 10w40 should only be used an a short term substitute).
Other fluids will work, but I will only use Honda MTF from now on.
Old Mar 4, 2010 | 01:14 PM
BryanM.'s Avatar
Resident Gearhead
2 quarts is enough, '92 Civic manual says it takes 1.9 quarts to fill the transmission.
Seriously man, don't put 75w90 in there.
Old Mar 4, 2010 | 01:40 PM
ugh lol, thanks man, so should i just buy a 10w40 motor oil? i'm sooo lost here, i'm told that motor oil
isn't designed for the high pressure of a tranny, and as u stated the civic manual states it's only a short
term substitute...so what should i run?
Old Mar 4, 2010 | 01:50 PM
BryanM.'s Avatar
Resident Gearhead
I would use Syncromesh if you can get it, 10w30 or 40 as a last resort.
Don't use gear 75w90 gear oil.
Old Mar 4, 2010 | 02:30 PM
ok i'm still confused on what exactly to buy, my local auto zone is very limited...if 10-40 motor oil is a last resort, besides
sycromesh what can i use..
Old Mar 4, 2010 | 02:31 PM
20w motor oil...
Old Mar 4, 2010 | 02:34 PM
i see royal purple has a 10w so i assume 10w is fine, so i should look for a 10w sycromesh?
Old Mar 4, 2010 | 03:08 PM
Kista20's Avatar
The pennzoil syncromesh is what weight that it is so it only comes in one flavor. You can get the gm syncromesh which is the same thing they have two flavors, one for normal open differentials and the second has a friction modifier additive for lsd. I would just goto autozone and get the pennzoil as it will be cheaper. I've been running it in my hx 5 speed for at least 60k miles now and nothing has happened one bit to the tranny or anything. When I switched to the syncromesh this was before honda brought out their new stuff so it's been a long time but before that I ran the honda mtf and I wasn't happy running that but the new is supposed to be like 1000x better from what I've heard.
Old Mar 4, 2010 | 03:19 PM
thanks! so just get the pennzoil syncromesh and call it a day, regardless of weight?
Old Mar 4, 2010 | 04:02 PM
although for gm models will the pennzoil syncromesh work for me? if not, besides honda mtf what can i safely run?? please i need to kno asap
Old Mar 4, 2010 | 04:10 PM
ok if all else fails, where can i buy honda mtf? like i know the honda dealer but any regular auto stores?
Old Mar 4, 2010 | 04:45 PM
is 75-90 really too thick as stated above? cuz the autozone guy said he has it in his honda and its fine.......
Old Mar 4, 2010 | 05:03 PM
BryanM.'s Avatar
Resident Gearhead
He's a dumbass. That stuff is as thick as honey.
Syncromesh is fine, Honda MTF is ideal IMO.
Old Mar 4, 2010 | 05:40 PM
es01civy's Avatar
Only reason why they say to use OEM stuff for there vehicles, because its THERE vehicle. They will make more money off of you if you stay with there brands. If honda had there own tires or any other manufacture they would say recommend only our tires. same principle. All fluids meet certain additives and that can be found just by looking in the back of the bottle.
Old Mar 4, 2010 | 05:43 PM
ramirez's Avatar
well the guy at the zone sounds like a douchebag lol get the hmt fluid if not syncromesh and 10/30 motor oil and u should be fine hommie gl
Old Mar 4, 2010 | 06:12 PM
300whpej's Avatar
a local aftermarket shop that works with hondas/acuras should have some also
Old Mar 4, 2010 | 06:17 PM
BryanM.'s Avatar
Resident Gearhead
Honda MTF has proven to be some pretty good stuff though.
Old Mar 4, 2010 | 08:49 PM
honda-junky's Avatar
https://honda-tech.com/forums/acura-integra-6/honda-mtf-gm-synchromesh-modified-706760/
FWIW I use the Lucas 80/90 and its the same as Syncromesh... goes in like molasses, but works awesome. Lucas 80/90 stopped a 3rd gear grind on my DD Integra with 280,000 Miles on the tranny.
95_Civic_4dr
Sep 16, 2009 10:05 AM
TravisCadello
52
Apr 15, 2009 02:47 PM
eag36
Oct 12, 2005 12:50 PM
vtec_head
15
Oct 2, 2003 05:38 PM
