Lower ball joint bolt rubbing against rotor
I know there was another similar thread, but I wanted to see if any new faces can come up with the solution. The problem happened after I swapped out my ITR struts and springs for progress coilover kit, but I didn't notice much until I replaced my passenger side axle, tie rod end,and lower ball joint. My only guess would be the blox camber kit that the previous owner already adjusted for the ITR suspension. Thanks in advance.
tuphatt
11
Sep 15, 2004 12:10 AM
