will itr rods and pistons fit in a b16a (cable)
i have a 91 crx si w/b16a1, (cable), i am getting a good deal on itr rods and pistons w/rings and pins, i was wondering if they will work fine.
all b series pistons are interchangeable, same diameter except for B20...displacement is computed by bore x stroke...same bore different stroke. LS motor has more stroke, more torque...B16, B18C1/C5 less stroke, higher rev, higher comp pistons = more power
Rods won't work unless you change ALOT.
Keep the B16a rods, the Type R's are no stonger, just a little longer.
B16a's with ITR pistons make about 11.0:1 compression and are VERY fun compared to the 10.2:1 stockers. Expect 10 HP or more once it's tuned.
[Modified by SiR Kid, 11:07 AM 9/8/2002]
Just for info's sake ...the ls Has 127ft/lbs the the GRS has 128 and the R has 129
, but the LS does make its peak torque earlier than both the Ls makes it at 5200 the Grs @6200 and the R @ 7500 .
-Jake
, but the LS does make its peak torque earlier than both the Ls makes it at 5200 the Grs @6200 and the R @ 7500 .-Jake
the pistons will work, make sure they are the same size bore. the rods will NOT work, they are longer, which means the pistons will hit the cylinder head.
ricky05
Feb 23, 2006 06:13 AM
