Help! Removing stripped bolt
Old Mar 3, 2010 | 11:37 AM
Momentum's Avatar
Default Help! Removing stripped bolt
Hey guys im trying to remove my log-style exhaust manifold and theres one last bolt that i just cant get... Its the one in the middle underneath the manifold, so i cant get a socket on it and a wrench is just stripping it more. I dont have access to a welder, are there any special tools that would fit in the small space?
Old Mar 3, 2010 | 12:22 PM
97twodoor's Avatar
Default Re: Help! Removing stripped bolt
You can't get it from underneath?
Old Mar 3, 2010 | 12:37 PM
alphalanos's Avatar
this
plus properly sized open wrench. wrench should be thin enough to get some rotation. an adjustable wrench is probably too big.
Old Mar 3, 2010 | 01:17 PM
mwaedow's Avatar
That one is trouble. If you have a slim pair a vise grips, you can try grabbing it that way. Try both 6-point and 12-point wrenches, otherwise, cut that bitch off.
Old Mar 3, 2010 | 04:55 PM
Momentum's Avatar
The oil dipstick is right underneath it so it blocks a lot of movement, i bought some needlenose vice grips today so i will try that tomorrow morning, if that doesnt work i will buy that stripped bolt thing if i can find it.
Old Mar 3, 2010 | 05:17 PM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
I recommend what alphaalanos said. Also, Try and use 6-point wrenches and sockets on old cars. They get more grip along the whole face of bolts/nuts and are less likely to round the edges. Also, try finding the next smallest US Standard size wrench (not metric like what the nut is). Sometimes mixing the standard on rusted the nuts with round edges will help. Good luck.
Old Mar 3, 2010 | 05:21 PM
Momentum's Avatar
Originally Posted by alphalanos
this
What is the name of this piece here? Are they easy to find?
Do these need to be hammered on? Or should it slide on ok... because there is no room to bang a piece onto the nut.
Old Mar 4, 2010 | 10:33 AM
mrspeedy69's Avatar
Spray some PB Blaster on it too.
Old Mar 4, 2010 | 12:15 PM
redrocket_ej1's Avatar
You can get the ones like that at Sears.. I wanna say its like $20 for a set of 5. Don't get the ones from Harbor Freight, they don't work very well. And yeah soak it in pb blaster like the guy above me said.
Old Mar 4, 2010 | 12:24 PM
97hxkidd's Avatar
cutting torches
Old Mar 4, 2010 | 01:05 PM
420eg95's Avatar
just spray some DW-40 to get rid of that rust, use a torch even a $35 cheap one will work, and it should come loose.
don't use vise grips untill you've tried evething, and don't cut it off! or you will be driling, then using a tap and die, and you will also have to buy a new screw and the tool used to screw it in with out stripping the threads,
Old Mar 4, 2010 | 05:23 PM
D Griff's Avatar
^^ My saving grace in auto mechanics.
Old Mar 4, 2010 | 05:38 PM
ramirez's Avatar
if you are acessable to air tools use an air chizzel and cut the nut in the middle to split it but make that ur last resort good luck keep us updated
Old Mar 4, 2010 | 06:04 PM
red Teggie's Avatar
What alphalanos mentioned works fine if applying pressure from the front, but since you probably won't have too much leverage pushing on the nut, it might be tough..
if nothing else works, you can try this.. you can probably get it from the top.. just another option..
G/L with that. I hate seized bolts..
Old Mar 4, 2010 | 06:40 PM
98civdx's Avatar
Master Detailer
they make this tool that sears sells i think its called grab its?? not sure, i think it was like 20 30 bucks and is a damn life savor,
Mishako129
Aug 18, 2012 12:08 PM
acmoc
13
Dec 20, 2008 11:12 AM
kyorishin
Apr 11, 2006 11:02 PM
GrandMarkie
May 17, 2002 12:53 PM
