Detailing Auto Detailing and Concours
DETAILING TIP OF THE WEEK
Old Mar 3, 2010 | 10:27 AM
SMARTWAX's Avatar
Default DETAILING TIP OF THE WEEK
I KNOW WE ALL KNOW SOME TIPS...SO BRING IT ON! FOR THOSE THAT DONT KNOW!
Old Mar 4, 2010 | 05:43 PM
Wakes4Fun's Avatar
Default Re: DETAILING TIP OF THE WEEK
Never drop your wash mitt. And always use gritgaurds and two bucket method.
Old Mar 4, 2010 | 07:24 PM
DynastyRacer22's Avatar
dont wax your car in direct sunlight
Old Mar 6, 2010 | 06:32 PM
redboost10's Avatar
unless you are using poorboys world products
Old Mar 11, 2010 | 11:22 AM
SMARTWAX's Avatar
or chemical guys or smartwax....
and here is my tip for this week
Detailing tip of the week: reason why a microfiber towel has two sides is because one side its for applying a product and the other to buff the product off. that's why always be picky about the towels you buy and what you use them for...
Old Mar 11, 2010 | 12:24 PM
crob621's Avatar
Whats the two bucket method??
Old Mar 11, 2010 | 01:12 PM
redboost10's Avatar
one bucket with soap and water, other bucket to rinse the mitt before dippinig it back in the soap and water bucket
Old Mar 11, 2010 | 01:17 PM
crob621's Avatar
oh ok got ya thanks
Old Mar 12, 2010 | 07:02 AM
MUGEN182's Avatar
Havent heard of this before. Sounds like it would work well...
Old Mar 13, 2010 | 04:04 PM
C_Rock77's Avatar
Only way to go! If you only ever learn ONE thing about detailing, learn THIS one!
This is how you do a "Quick & Easy Wash," too.
Check out this stuff to know what I'm talking about.
http://www.autogeek.net/dp-rinseless-four-in-one.html
Old Mar 15, 2010 | 12:08 PM
WhiteSlips's Avatar
My tip for the week-
Tape off trim and emblems while applying polish and wax to help remedy the dreaded white on black trim staining. Also helps to tape over the edge of the molding so no wax or polish can get in the cracks between the body and molding.
Old Mar 15, 2010 | 12:26 PM
redboost10's Avatar
kinda common sense, but when claying, do not just use water...at least use soap and water, but its best to use some quick detail spray. i personally use ONR.
Old Mar 16, 2010 | 07:20 PM
flip28001's Avatar
TRIAL USER
the best way to clean your dirty airvents an between the seats an armrest is to use blow it with an air compresser. spray windex in the vents helps lossen the dirt an then blow it out. air is also good to get pet hair up.
Old Mar 16, 2010 | 08:30 PM
1.5Slowmatic's Avatar
when wiping off buffing compounds, use a 50/50 mix of rubbing alcohol and water to make sure the surface is clean for the next step.
Old Mar 16, 2010 | 09:40 PM
dapek's Avatar
True, air is a must on most interior work. Windex is not good to use on interior plastics, other appropriate chemicals are made for use w/ interiors.
Old Mar 16, 2010 | 09:41 PM
Jguti23's Avatar
TRIAL USER
use claybars to remove imperfections in paint like stickers residue and overspray do not drop on floor if u do throw it away it will destroy ur paint if u use it
Old Mar 16, 2010 | 09:44 PM
dapek's Avatar
I hate to break it to you, but every type of towel has two sides. Microfiber cloths are the same on both sides and are not used to apply anything that you would buff, generally you would use them for removal.
Old Mar 17, 2010 | 05:51 AM
not all microfibers are the same on both sides. I know some of mine aren't. My cobra towels have different sides to them. One is a softer side and once is a little more dense
Old Mar 17, 2010 | 11:01 AM
SMARTWAX's Avatar
Proper detailing towels will make any detailing job a breeze, SmartWax recommend high grade microfiber towels with 70/30 blend like our Monsters Towels 16x16,
http://www.smartwax-usa.com/ProductD...de=MIC_1100_03
Old Mar 17, 2010 | 06:19 PM
dapek's Avatar
Oh snap forgot about cobra. Those are quality
Old Mar 17, 2010 | 06:20 PM
dapek's Avatar
Hmm..seems like this thread is turning into your product placement section?
Old Mar 22, 2010 | 10:47 PM
sky9's Avatar
any tips on removing water stain/mark on hood?
Old Mar 23, 2010 | 06:06 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Most likely will take a good polish compound on a straight-drive polisher to correct it.
Old Mar 24, 2010 | 09:41 AM
SMARTWAX's Avatar
for water spots i've always use wax...
Old Mar 24, 2010 | 09:42 AM
SMARTWAX's Avatar
Detailing tip of the week : what to do first when detailing your car (interior, engine, wheels and last exterior)
