DETAILING TIP OF THE WEEK
or chemical guys or smartwax....
and here is my tip for this week
Detailing tip of the week: reason why a microfiber towel has two sides is because one side its for applying a product and the other to buff the product off. that's why always be picky about the towels you buy and what you use them for...
This is how you do a "Quick & Easy Wash," too.
Check out this stuff to know what I'm talking about.
http://www.autogeek.net/dp-rinseless-four-in-one.html
My tip for the week-
Tape off trim and emblems while applying polish and wax to help remedy the dreaded white on black trim staining. Also helps to tape over the edge of the molding so no wax or polish can get in the cracks between the body and molding.
the best way to clean your dirty airvents an between the seats an armrest is to use blow it with an air compresser. spray windex in the vents helps lossen the dirt an then blow it out. air is also good to get pet hair up.
Windex is not good to use on interior plastics, other appropriate chemicals are made for use w/ interiors.
not all microfibers are the same on both sides. I know some of mine aren't. My cobra towels have different sides to them. One is a softer side and once is a little more dense
http://www.smartwax-usa.com/ProductD...de=MIC_1100_03
Proper detailing towels will make any detailing job a breeze, SmartWax recommend high grade microfiber towels with 70/30 blend like our Monsters Towels 16x16,
