ECL #9 OBD 1
Old Mar 1, 2010 | 03:39 PM
918EKcivic's Avatar
New User
Default ECL #9 OBD 1
i looked it up and it says that it's a cylinder sensor. how do i get this problem fixed? ECL came on about a week ago. stopped driving the car since. it's a 2000 civic hatch with gsr swap and converted to obd1 running hondata s300 on p28. any info would greatly be appreciated.
Old Mar 1, 2010 | 05:47 PM
delsolproblems's Avatar
Default Re: ECL #9 OBD 1
If the ECU is fine and the wiring is ok then you need a new distributor. The CYP sensor is part of the distributor and isn't usually available by itself. You can test the sensor by disconnecting its connector at the distributor and checking the resistance across the two CYP wires. It should be between 350 and 700 ohms. Just because it tests ok doesn't necessarily mean it isn't malfunctioning.
Old Mar 2, 2010 | 08:59 AM
918EKcivic's Avatar
New User
alright. thanks for the info i'll try that out this weekend. only time that i'll have to work on the car.
C_Rock77
Apr 21, 2010 07:44 PM
civicsi_5289
Aug 25, 2008 09:36 PM
riftonthemind057
Mar 27, 2008 01:08 PM
alexsracing
Nov 20, 2007 10:17 AM
