dropped car into 2nd at 30, trans locked up ...car screeched to a stop
Old Mar 1, 2010 | 02:23 PM
$Tweezy's Avatar
Default dropped car into 2nd at 30, trans locked up ...car screeched to a stop
hey just as the title says i was taking a turn today, dropped the car from 3rd to 2nd and as soon as i let the clutch out the car when BAM and screeched to a stop. like 30mph-0 in no time. afterwards i started it up, the motors fine i didnt however try any gears just in case it would **** something else up.
shift linkage?
throwout bearing?
synchros??
i just got a new stage 3 today and want to put it in but not if the cars doing this
Old Mar 1, 2010 | 02:43 PM
mark2583's Avatar
Default Re: dropped car into 2nd at 30, trans locked up ...car screeched to a stop
Wow i want to know too. Sounds like the tranny to me.
Old Mar 1, 2010 | 02:51 PM
GlassJAw's Avatar
Is your tranny a non LSD model??
Sounds like the pin has dropped through the differential and locked against the casing.
Is there a hole in the side of the tranny??
Has there been any strange sounds coming from the tranny area recently??
Old Mar 1, 2010 | 02:54 PM
$Tweezy's Avatar
ya its definetly all in the trans.
its a h22 swapped accord.
I did the swap last summer, i ripped off the trans and the clutch/flywheel/pressure plate were all in good shape. The only thing that looked scummy was the linkage. I had read that if its real easy to move the car from gear to gear with no clutch while the car is off your linkage is most likely slipped or broken. I had adjusted the clutch too when i did the swap. Oh and i neglected to check the throwout bearing.
should i just throw some new cables and dump a bottle of synchromesh down there?
Old Mar 1, 2010 | 02:57 PM
$Tweezy's Avatar
yea h22a with the non-lsd trans. I didnt check out the diff box at the time i was just so mad and wanted to grab a beer. There is a weird whirring noise sounds like the halfshaft but now that i think about it, it could have very well came from the diff box.
I got my stock f22 trans still in storage ill check it out tomorrow too see if there are any holes in it. (the h22 one)
Old Mar 1, 2010 | 11:31 PM
GlassJAw's Avatar
Can you move the car with it out of gear?? (as in push the car with neutral selected)
If you can I would rule out my theory (which I am hoping is the case for your sake!!)
Old Mar 2, 2010 | 03:50 AM
ilikehonda's Avatar
thats odd.....that shoulda been nothin for that trans
Old Mar 2, 2010 | 06:05 AM
dagle's Avatar
yeah lol weird indeed... 1st gear in the h22 tranny is about 35mph on 205/50/16 tires, 2nd should shrug 30mph off easily.
Old Mar 2, 2010 | 03:06 PM
02 accord's Avatar
Either the diff locked against the case, or you have a bent/broken shift fork. If the latter is the case, you'd be in 2nd and 3rd gear at the same time, locking up the trans. If in neutral, the car rolls with the clutch pushed in but not with the clutch out, you have a shift fork that's holding the trans in gear.
Old Mar 4, 2010 | 12:20 PM
$Tweezy's Avatar
i can push it in neutral....i still havent gone and looked at it just so i dont get all angry lol but this weekend, i plan to install my new stage 3 and before i do that im going to stop at the storage and grab my f22 trans...when i take it out ill inspect the gearbox, the throwout bearing, shift fork etc.... and try driving it in gear...
yea that trans has taken some abuse though, i taught my girl to drive that car and when she first started she would hit 1st at like 50 duhhh on accident of course but it has always held up through that abuse
Old Mar 13, 2010 | 09:28 AM
$Tweezy's Avatar
whoooo well i got down to it last night some more and dropped the trans,
turns out the ball socket on the shift fork was never greased, i never checked it but i guess that motor had probably been sitting a WHILE at tiger, anyways it trashed the fork and throwout bearing....whoulda thunken?
Old Mar 13, 2010 | 09:33 AM
$Tweezy's Avatar
thanks man after i read your post, i re read mine and it said "when i let the clutch out, it..." i neglected to see it at first thank u my good man
shuiyuan
Nov 14, 2012 04:42 PM
VtecVillan
10
Oct 29, 2007 09:53 PM
ultra efro
Jan 3, 2005 03:47 PM
wreckedmyteg
Jun 9, 2004 07:22 PM
OldSchoolCrxSiR
Jun 8, 2002 12:06 PM
