car wont rev past two-step
Old Feb 28, 2010 | 08:48 PM
mhewitt's Avatar
Default car wont rev past two-step
ok i ordered a chip for my ls/vtec eg coupe from phearable.net with a two-step launch rpm of 4000rpm. after installation of chip i go for test drive n car wont rev past two step when going down the road. i have no check engine light on so what could be the cause of this??
Old Feb 28, 2010 | 08:52 PM
Top Ramen's Avatar
Default Re: car wont rev past two-step
You should call Phearable tech support.
Old Feb 28, 2010 | 09:18 PM
mhewitt's Avatar
i tried that it said email for tech questions so i did and im waiting for an answer from them, just thought i would see if anyone else could help me sooner. and its good info for future reference if it gets answered correctly...
Old Feb 28, 2010 | 09:31 PM
HRTuning's Avatar
The basic 2-step is speed based, which means your VSS sensor signal is not reaching the ECU properly either because of the sensor itself or the wiring.
Old Feb 28, 2010 | 11:49 PM
.adam.'s Avatar
bad speeeeeeeedo
Old Mar 1, 2010 | 05:18 AM
TurboLSVtecTeg's Avatar
It doesnt necessarily mean that the VSS sensor is bad. Alot of times I've found the pins to be corroded for the VSS plug. I usually just cut a spare pigtail of another harness and soder it in and all is good. Its usually the middle pin that is the worst. Which if memory serves me right is the 12v power too the sensor.
Old Mar 1, 2010 | 03:42 PM
mhewitt's Avatar
vss was same one that was working on the d series in the car before i swapped in the ls/vtec so thats why i didnt think that was causing it. n my speedo still works fine, could it still be the problem?
Old Mar 1, 2010 | 04:10 PM
mhewitt's Avatar
bump for some help
Old Mar 1, 2010 | 04:22 PM
HRTuning's Avatar
Yes, just because it makes it to the dash does not mean it makes it to the ECU. Check the wiring.
Old Mar 1, 2010 | 05:03 PM
mhewitt's Avatar
ok will do, but it is ok to use the d series one in a b series tranny right?
Old Mar 1, 2010 | 08:01 PM
mhewitt's Avatar
bummmppp
Old Mar 1, 2010 | 09:45 PM
mtber's Avatar
To get technical support all you had to do is go to http://www.phearable.net & click on contact.
If you are having issues with your vehicle not being able to exceed the 2 step rpm you need to do the following:
1. Check your codes.
2. Check to see if a speed signal is being reported to your ecu.
The ecu needs to see a vehicle speed before it will allow the vehicle to exceed the 2 step rpm.
Let me know if I can answer any other questions.
Old Mar 2, 2010 | 10:38 AM
mhewitt's Avatar
ok i swapped the ecu out with the one from my b20vtec hatch but still used the phearable chip for the ls/vtec and it worked perfectly so i guess i just bought a bad p28? thanks for everyones help, phearable basemaps are awesome! second car ive run one on and both perform flawlessly.
Old Mar 2, 2010 | 04:35 PM
mtber's Avatar
Glad to hear you figured it out & I am glad to hear our basemap is performing awesome!
Old Mar 2, 2010 | 08:18 PM
Top Ramen's Avatar
It could be the pin for that signal is wonky or loose.
Old Mar 4, 2010 | 04:54 PM
darrinbrewer's Avatar
i had this happen. track car, VSS wasnt plugged in, like everyone says, its speed based.
Old Mar 8, 2010 | 07:24 PM
mhewitt's Avatar
when i use my ecu outta my other car (b20vtec) with this chip in it (ls/vtec) it revs like it should but idles erratic, when i use this chip in the p28 it idles fine but wont rev past twostep and runs pretty terrible (bad ecu), so now i chipped my po6 but did not convert it to vtec yet and it idles fine n runs great but i cant rev past two step again. y would the vss signal make it through to b20vtec ecu but not to the other two? is it because the po6 isnt converted to vtec yet?
Old Mar 8, 2010 | 07:59 PM
mhewitt's Avatar
bummmpp
Old Mar 8, 2010 | 08:40 PM
mhewitt's Avatar
any info on why this might b happening?
Old Mar 10, 2010 | 07:08 PM
mhewitt's Avatar
anybody have any ideas?
Old Mar 10, 2010 | 07:52 PM
mhewitt's Avatar
Mauro87
13
Jul 15, 2012 05:16 AM
4genciv04
Apr 28, 2009 12:15 PM
tekturbo
May 28, 2008 07:59 AM
dc2much
Apr 5, 2008 02:50 PM
nautica_t
27
Oct 29, 2002 03:39 PM
