My D16z6 rebuild
Old Feb 28, 2010 | 03:49 PM
adriftfoolish1's Avatar
Default My D16z6 rebuild
I figured I'd post a few pics of the rebuild I'm working on this week. Not much else to do and I can answer questions if anyone is thinking about doing their own.
Putting the new valve stem seals on. Mic'd everything while I was at it.
Guy that had this engine before me tried to rtv the lma holder! ha!
Cam lubed up, new lma holder and torqued it all down.
Just seeing what my diy paintjob on the valve cover looks like.
Old Mar 1, 2010 | 03:43 AM
Honda Race #10's Avatar
Default Re: My D16z6 rebuild
OK i race at sauble speedway and i am doing the complete swap lk from DPFI to MPFI so i put the whole wiring harness in now the engine is siting on the floor in my shop what do i need to do to it while it is out things i have already done to it are... replace water bypass tube and o rings cleaned the screen in the vtec... replaced the thermostat and cleaned up the intake ( got it nice and shiny in side and out got all that black crap out of it lol...) thanks Will G
Old Mar 1, 2010 | 03:23 PM
Well as long as it was running good before I'd try to do as little as possible! If it ain't broke.. If the engine is really greasy like there are some slow oil leaks I'd get a gasket kit from autozone. Oil pan, head, cam front, spark plug tube seals, etc. felpro kit for about $100. It has some gaskets and seals that you won't really need though unless you plan on taking it all apart.
Old Mar 1, 2010 | 06:33 PM
OK thanks... now i have some tokico shocks are they a lot stiffer than stock or? and i also bought a light weight fly wheel 11 pounds will that give me good acceleration ...
Old Mar 1, 2010 | 06:35 PM
o and i also got a ajustable timeing gear that will alow me to set my power band where i want it right ? but my main question is the stock cam gear has like a tapered key in it and the ajustable one does not what does that mean do you know?...
Old Mar 2, 2010 | 05:48 PM
I can't say about your shocks. you should get better throttle response with a lighter flywheel, but I think 11lbs is just under the weight of the stock one isn't it?
Old Mar 2, 2010 | 06:30 PM
vtec8200's Avatar
You need a woodruff key to lock your cam and cam gear. I used some from a b18 I had laying around, you can order it from honda.
Old Mar 3, 2010 | 06:10 PM
ok thanks man
Old Mar 6, 2010 | 04:52 PM
hey Mann can i use a s20 transmission from a 92-95 civic in a 91 civic Si cause of the d16z6 that i have in it now it wont wok with the 91 Si tranny no speed sensor so can i use a s20 in my 91 and do they have a s20 with cable clutch not hydraulic
Old Mar 10, 2010 | 03:03 PM
Sargenttoji's Avatar
do i need to replace the valves and valve springs? Im adding a stage one cam. I did the easy stuff like replace the pumps and belts and gaskets. This is my first rebuild in terms of a slightly tuned motor.
Old Mar 12, 2010 | 06:33 AM
Does the manufacturer suggest you install different springs? It's not that hard to do. If you're replacing the gaskets you should do the valve oil seals too anyhow.
Old Mar 12, 2010 | 08:37 PM
Bearings finally came in the mail
Just laying the head on for the night. I'll put everything else on sometime this weekend.
Old Mar 18, 2010 | 05:06 PM
HyDru
19
May 24, 2019 12:06 PM
justa4banger
Nov 10, 2008 07:43 PM
justa4banger
Nov 10, 2008 07:41 PM
boostedcivichatchbacksi
Sep 11, 2004 12:40 AM
Evs-One
65
May 12, 2003 03:14 PM
