ac recharging
Old Feb 28, 2010 | 01:29 PM
Steve LeB's Avatar
Default ac recharging
I blew an ac hose on my 97 accord. What is the best way to recharge the system?
Old Feb 28, 2010 | 01:57 PM
YeuEmMaiMai's Avatar
Default Re: ac recharging
have a shop do it
Old Mar 1, 2010 | 02:19 AM
hondamark35's Avatar
i second that.
it's important to get the exact amount in there and then check the pressures and cooling capabilities to ensure it was done right. thosee little bottles from the auto parts store won't get you there. the machine you would need to do it right... around $3,000 for a good used one.
Old Mar 1, 2010 | 12:34 PM
cstone's Avatar
Originally Posted by hondamark35
i second that.
i also second letting a shop do it.
another problem with those bottles is that there is a reason that you are recharging it. your A/C shouldnt ever need recharged unless it is leaking somewhere. with the bottles you wont be able to find the leak to fix it. you need the $3,000 dollar machine to be able to put dye in there to find the leak.
OP you said that you blew an A/C hose, how did that happen? just trying to find out if there may be an underlying problem that cause this to happen in the first place...
Old Mar 1, 2010 | 01:59 PM
Originally Posted by cstone
OP you said that you blew an A/C hose, how did that happen? ...
i was thinking the same thing.. i've never seen one blow! the system should shut off it the pressure goes high long before hoses bust..
Old Mar 1, 2010 | 02:19 PM
cstone's Avatar
aren't all the A/C "hoses" technically lines (metal) anyways? "hose" would mean that its rubber. maybe it isn't really an A/C line? that or he just called it a hose instead of a line. i just can't think of anything that would cause a metal A/C line to blow.... i guess we wait till the OP responds.
Reddman21
Jun 13, 2017 08:52 PM
Bear7285
May 18, 2013 05:03 PM
methods555
Jul 22, 2007 08:26 AM
mnm99
Apr 23, 2005 07:21 AM
AlphaKennyWun
Jan 23, 2002 05:24 PM
