Idle issue 94 b18b1
Old Feb 27, 2010 | 06:38 PM
_Keith_'s Avatar
Default Idle issue 94 b18b1
So ive done a swap. Had no problem did a complete rebuild.
All of a sudden lately at idle the revs go up and down 250-500 rpm.
I replaced the map, and the IACV still does it...
Looking for ideas, and help.
Old Feb 27, 2010 | 07:09 PM
seanbev24's Avatar
Default Re: Idle issue 94 b18b1
It's probably either a vacuum leak or an issue with the fast idle thermo valve (fitv)
Old Mar 1, 2010 | 05:18 PM
_Keith_'s Avatar
Ive checked for vacuum leaks... whats the best way to do this?
fast idle thermo valve (fitv) <--Where is that located?
And thanks for the help... good to know some people still here to help.
Old Mar 1, 2010 | 09:40 PM
_Keith_'s Avatar
So I found a post about the fast idle thermo valve (fitv). Tore it open cleaned it.. put it back in.... same problem...
Any other ideas why I have a weird idle about 250rpm to 500
typer_696
Aug 8, 2009 01:43 PM
b20eg9daddy
Oct 25, 2008 12:37 PM
94SHOWLS
Feb 17, 2005 12:31 PM
SLOAZZ95
Nov 5, 2003 04:42 PM
TurboCRVTEC
Oct 9, 2002 05:38 AM
