Timing belt broke easiest way to check valves?
Old Feb 27, 2010 | 03:49 PM
turboedsupe's Avatar
Default Timing belt broke easiest way to check valves?
So was going about 75mph when the timing jumped and my motor bogged out. Got the timing belt off and all the ribs are gone and the belt is smooth. So now that i have the vc off and everything that was required to take the t-belt off what is the easiest way to check to see if the valves are bent? I heard leakdown but i read the engine should be warm and well i cant start it. Also dont have a leakdown tester and cant find one locally. Is there a better way or should i just get my hands on a leakdown tester and do it with the motor cold?
Old Feb 27, 2010 | 05:48 PM
96accordsir's Avatar
Default Re: Timing belt broke easiest way to check valves?
samething happened to me and all my valves were bent looks like its time for a rebuild...
Old Feb 27, 2010 | 10:40 PM
Romo Pyro's Avatar
Compression test asap, then check valve lash, excessive clearance indicates bent valves.
Old Feb 28, 2010 | 10:06 PM
Scott_Tucker's Avatar
Yes, check valve adjustment. If clearance is more than .005" - .010" too loose, it has a bent valve for sure. Or you can just throw a belt on it and see how it runs if you are doing the work yourself.
Old Mar 2, 2010 | 09:09 AM
89vwfox's Avatar
i agree compression test and check lash
Old Mar 2, 2010 | 09:48 AM
tofast4uh22's Avatar
pull the cam or cams out of the engine and run a leak down test. or you could crank it over and run a compression test. just make sure the cam or cams are not present so that way no valves are left open.
Old Mar 2, 2010 | 11:12 AM
welfarepc's Avatar
exactly what i was just typing up.
Old Mar 2, 2010 | 07:05 PM
Pssst!'s Avatar
This should be the easiest way and cheapest way since you already have the vc off. you'll just need a feeler gauge set.
A bent valve will not properly seat. Therefore the valve clearance adjustment will be too loose.
Old Mar 3, 2010 | 04:29 PM
PariahBoardshop's Avatar
In for the results.
Old Mar 3, 2010 | 11:47 PM
dntnedvtec's Avatar
Yeah, but I'd say, slap on a new timing belt, adjust till TDC, and do a compression test. That way, if you were lucky, you'd save al the trouble of tearing everything apart. Take this:
96 GSR, I broke a timing belt while cruising about 45 mph, car dies, and my dumb **** tries to crank it. Everyone thought bent valves, but nope. We got lucky....Very lucky.
Old Mar 9, 2010 | 07:04 PM
Blaze45's Avatar
Brrraaaap!
Loose T belt+ 6000rpm =2 skipped teeth on the timing gears... I got really lucky. Car just bogged out and I didn't have any bent valves.... I thought I blew my engine though, I had the head off 20min after the belt skipped the teeth lol. When I pulled it off only to find nothing wrong with the head or block and I was stumped and very surprised. Got a new headgasket, threw it together and walah - I was back in business.
Good luck.
jeffriesjr
Apr 1, 2019 11:01 AM
hondaZvic
Sep 29, 2007 12:18 AM
06Xrunner
Nov 25, 2003 09:18 AM
Shannons52
Jul 14, 2003 07:25 PM
Redline130
Aug 13, 2001 10:09 PM
