I need help fast!! 97 crv pulley problem
I bought a jdm b20b to replace the engine in my crv. I bought a new belt from autozone and it dont fit. I checked the crank pulley from the jdm motor and the pulley diameter for the ps is much bigger. I do not have usdm pulley anymore because it broke when the keyway fell out of the old motor. What other pulley works on this? what are my options? Besides buying a new one from honda. I cant find one used anywhere.
You could maybe try a longer belt, or get another pulley with an inside hole that's the same diameter as the one that's on there but with a smaller outside diameter.
i understand using another pulley, my question is what will work. A longer belt is not an option cause the bigger pulley diameter puts the belt out too much and it touches the torque mount
mrowxlived
Sep 9, 2017 10:54 AM
jbell
Welding / Fabrication
Oct 28, 2008 11:03 AM
